No Mess Oil Change
Old Sep 7, 2006 | 03:12 PM
00Runner's Avatar
Originally Posted by Crux
How do you avoid spilling when removing the oil pan bolt through a tiny hole in aftermarket skid plates? Seems like it will still splash all over the inside of the skid until you get the ratchet and hand outta the way.
Never had a problem with it with the stock skid plate since the hole is huge. It takes more finesse with my BudBuilt. The hole is only slightly larger than 2" in diameter and is much farther away from the oil pan than the stocker. Basically I try to get the bolt to the point where it is as loose as it will go without coming out. Then with just the socket and extension (no ratchet) I try to spin it and drop it as fast as I can. Not foolproof, but it works pretty good so far.
Old Sep 7, 2006 | 04:27 PM
rockota's Avatar
Easier solution:
http://www.4x4wire.com/toyota/tech/a...bypass_filter/
Old Sep 8, 2006 | 03:20 AM
OutdoorLiving's Avatar
I have an even easier solution that doesn't require as much work or stacking newspaper. I'll take pictures for my method the next time I change my oil (which will be as soon as the parts for the clutch come in).
Old Sep 9, 2006 | 10:12 AM
habanero's Avatar
Ok, don't laugh too hard. Had to do an oil change this morning so I dug around in the recycleables and picked out a cooking oil bottle, cut the bottom off and stuffed it in from underneath, under the lip just below the oil filter. It was aimed just past the skid plate and voila! no mess when I unscrewed the oil filter. Hooray!! (96 manual 3.4) No wrestling with skid plate. Hooray!!
Old Sep 17, 2006 | 02:13 AM
  #25
914runner's Avatar
My idea for a no-mess oil change is to get a filter relocator and relocate the filter to the front of the wheel well by the vacuum canister.
Old Sep 17, 2006 | 01:35 PM
  #26
animator's Avatar
I just stick to putting paper towels or shop rags under the filter while loosening. Then once it's off, flip it upward so no oil pours out.
I also remove the skid plate that's directly underneath the engine--not the one under the bumper.
Last time I changed the oil, I didn't even turn the tire, just reached in and grabbed the filter. This wouldn't work for some people with larger tires, but worked fine for me.
Old Sep 18, 2006 | 08:10 AM
  #27
I basically use Hab's approach, only I just leave the cap on and let it fill up the container and remove it. No more fuss.
Old Sep 18, 2006 | 08:30 AM
  #28
cackalak han's Avatar
I did mine yesterday, and didn't remove the skid plate. No big mess--just a few little drips. I just made sure to drain out the oil from the pan first, then scooched the drain pan under the filter while loosening it. Pretty simple process. Took less time than my previous cars, except the S2000.
Also just a thought. This thought does not apply to those using synthetic oils. Anyway, I bought Valvoline 10W-30 (6 bottles) and it came out to $19. Then I bought a Toyota Oil Filter, which came out to ~$10 or so (can't remember). The total was $29. I just went by the Toyota dealership, and they charge $28.99 for an oil change. Now, I enjoy working on my cars, but not the regular maintenance stuff--especially if someone else can do it for the same cost as doing it myself. Next time, I'm going to the dealership. Now, THAT'S a real "no mess oil change."
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
horunner1x
Jul 10, 2015 06:33 AM
HRDC0R19
Jul 5, 2015 06:43 PM
