New to Yota's
Old Mar 19, 2009 | 12:56 PM
robertcrav's Avatar
Question New to Yota's
Like I mentioned in the intro thread, I picked up a 1997 4Runner SR5, and I can't figure out why the rear cargo light does not go on when in the door position, and I lift the hatch? I looked around the outside looking for a switch, couldn't find one...am I imagining a functionality that should be there??
Makes sense to me that when I open the hatch, the light should go on...but what do I know
Thanks,
Robert
Old Mar 19, 2009 | 12:59 PM
MillerPKA's Avatar
There should be a switch to the right of the light with 3 positions, on - off - door. I can't imagine why they'd stiff you on that. Can you get the light to come on in any circumstance?
Old Mar 19, 2009 | 01:00 PM
1stgen4gunner's Avatar
I don't know if its like this on all 4runners, but there should be a little switch on the light itself and also one a little to the left about 6 inches under the steering wheel somewhere.
PS: WELCOME TO YOTATECH
robertcrav's Avatar
Sorry, should have been more clear, there is that switch, and it does come on, when I move it to on, but does not come on when the switch is in the door position with the hatch open
Old Mar 19, 2009 | 01:01 PM
robertcrav's Avatar
Thanks!
Old Mar 19, 2009 | 01:15 PM
okie81's Avatar
I had a similar problem, it was more like this though:
https://www.yotatech.com/forums/f2/t...its-not-66487/
Old Mar 19, 2009 | 01:20 PM
robertcrav's Avatar
What was the solution?
Old Mar 19, 2009 | 02:20 PM
okie81's Avatar
I sprayed the latch area with WD-40 and never had the problem again. The door open switch is tied to the rear door lock button, I believe, so you might wanna check that out.
Old Mar 19, 2009 | 02:55 PM
SoCalPaul's Avatar
The Cargo Light should come on when the hatch is open. Don't know where the switch is though.
Old Mar 20, 2009 | 08:32 AM
hawaiibake's Avatar
I have a similar problem where the light only comes on for the passenger doors being open and not the drivers door...
Old Mar 20, 2009 | 09:04 AM
97ltd4x4's Avatar
I believe the coutresy pin switch is located in the liftgate striker....Just checked online..$35 +shipping
Old Mar 20, 2009 | 09:46 AM
Godzilla's Avatar
So, just putting this out there, but did you by chance check/replace the bulb?
JonG85
Jan 18, 2023 04:31 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Ditch Doc
Oct 27, 2015 03:20 PM
shredder4286
Oct 1, 2015 01:09 PM
