Old Apr 21, 2016, 12:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
New Suspension Setup - TRD Front Lift for a 3rd Gen 4Runner!
Old Jan 10, 2005 | 08:02 PM
  #461
User 051420's Avatar
I really need those bumpstops....
Old Jan 10, 2005 | 08:16 PM
  #462
danny4runner's Avatar
This could be overkill, and probably is, but I am getting different color variations when asking different people in the forum about the colors of the Tundra Coils. When accessing 1st Toyota Parts, it lists 4 variations of the same model number, however the years differ too. I think Neil has yellow/yellow and blue/yellow. Schaefer told me to use purple/yellow and red/yellow. I am completely confused right now. Why all of the color variation and which ones do I need for the TRD 4WD Tundra coils? I know the part numbers, but I need the specfic year and color please. Thanks everyone
Old Jan 10, 2005 | 08:18 PM
  #463
All you need are the part numbers. The years don't matter. If you order the AF090/AF100 coils you'll get the Yellow/Yellow & Blue/Yellow coils.
Old Jan 10, 2005 | 08:19 PM
  #464
Go here and type in the part number and select Toyota.
https://www.1sttoyotaparts.com/partscat.html
Old Jan 10, 2005 | 08:21 PM
  #465
Right on, I did but got thrown for a loop when the descriptions changed (especially the one for 2WD)
Old Jan 10, 2005 | 08:24 PM
  #466
sschaefer3's Avatar
Ooops, I have to fix that, the part numbers I gave you are yellow-yellow, blue-yellow.
That was before we knew.
Old Jan 10, 2005 | 08:27 PM
  #467
Whew...I feel better knowing that both you and Neil are in agreement about the colors being yellow-yellow, blue-yellow. Did either of you order through 1st Toyota parts? I'm just wondering whether I should call them to try to verify the colors when ordering?
Old Jan 10, 2005 | 08:31 PM
  #468
sschaefer3's Avatar
Ok, fixed.
http://fastq.com/~sschaefer/Tundra_Coils.html
That was from when Andy was buying coils from eBay and kept getting 2WD stuff.
I updated it. The part numbers were always right.
Old Jan 10, 2005 | 08:32 PM
  #469
sschaefer3's Avatar
I have ordered 3 sets from them with those part numbers. You'll get the right colors.
Also the parts guys will have no clue what the colors are, only the factory has that info. We already went through all this.
Old Jan 10, 2005 | 08:36 PM
  #470
Alright guys, thank for the help. I'll put in my order tomorrow and update as I install. Can't wait to try out this new setup! Many thanks to Andy, Steve, Neil and the rest of the people that helped me decide on this setup.
Old Jan 11, 2005 | 03:43 AM
  #471
Sherpa's Avatar
Originally Posted by waskillywabbit
Read the thread newb if ya want the 411 or PM bamachem.
Newb??? Check I've been a member of the forum a lot longer than you. Just 'cause I don't post much doesn't mean I'm new....
Old Jan 11, 2005 | 03:54 AM
  #472
waskillywabbit's Avatar
Talking
Then you should know better than to post up asking questions...not having read the whole thread.
Old Jan 11, 2005 | 04:27 AM
  #473
bamachem's Avatar
So, bamachem, how much do you think you are in for $$$ with the entire front end done? I have some coil springs waiting for me in Kentucky, so I don't need to worry about the rear right now.
-S
Front:
For 2.5" to match OME 890/891/892
Two sets of AE Spacers and one set of extended studs: $80 shipped
One set of Tundra TRD 4WD Coils: about $200 shipped (NEW)
One set of OME N91s Struts: about $220 shipped (NEW)
Re-use OEM top plate and rubber washer.
Total: about $500 new. You might be able to pick up some Tundra TRD coils in the $100 range if you're patient and look on ebay and Tundra Solutions.
If you're like me and go with the Downey's and carry a little weight in the back, then a single set of front spacers will be pretty level so you can knock off another $33.
Compare those prices to the OME stuff. 880's are way too short and will require a 2" or 2.5" Cornfed spacer that's $150. 881's are still too short and will require a 1" or 1.5" Cornfed spacer and that's still $150. 882's are stiff as hell, and by that time, you don't get as good of flex. They will also eventually sag as you flex them, requiring you to put in trimpackers or some of my spacers anyway.
OME coils are about $180 or so shipped. Add $150 for Cornfeds, then you're at $330 just to get the spring and lift. The Tundra setup is $280 and it gives a better ride and MUCH better flex at the same time. They use the same strut, so that's a wash when comparing numbers.
Old Jan 11, 2005 | 04:38 AM
  #474
sschaefer3's Avatar
I really think I would be content with the 2", Two spacer will be a beast to get in position, even with the 4 lower bolts out. Also the higher you go, the more CV wear. 2.5" is way worst than 2". Also with an Old Man Emu shock you will have to run limiting straps for sure.
For two spacers, I would get a shorter shock.
Old Jan 11, 2005 | 09:11 AM
  #475
RTdawgs's Avatar
I am running Tundra coils with 2 OME trim packers and no top spacer. This is giving me a lot more lift than my previous setups. I cant see how anyone would need 2 top spacers since i am getting approx 2.5" lift without one and i run a TJM/winch.
Old Jan 11, 2005 | 04:08 PM
  #476
bamachem's Avatar
Two trimpackers would be about the same thing as two top spacers as far as height goes...
Old Jan 11, 2005 | 04:28 PM
  #477
sschaefer3's Avatar
Bingo! But the ride will be stiffer. Got to keep it silly soft.
Alcan should keep me silly soft as well.
Old Jan 11, 2005 | 04:40 PM
  #478
Bighead's Avatar
Have you bought them yet? I bet the 44 is getting lonely...
Old Jan 11, 2005 | 04:49 PM
  #479
sschaefer3's Avatar
They have been ordered. Did you see this?
https://www.yotatech.com/forums/showthread.php?t=48960
Old Jan 11, 2005 | 04:56 PM
  #480
Bighead's Avatar
Yep...just checked it out.
Looks like pretty soon me and my IFS and 33s won't be able to hang with you anymore.
