new seats for the taco...what oems fit
Old Oct 15, 2005 | 06:15 PM
dfoxengr's Avatar
i have a 96 tacoma ext cab.
front seats are separate, but have the center bench section, that folds down into an arm rest also.
light gray in color.
i reall ywant to ditch them and fit some 4runner seats or something else that removes the bench, and adds a real center console
what do you guys know fits.
im in virginia incase someone has some also.
Old Oct 15, 2005 | 06:55 PM
EnolaGaia's Avatar
The only straightforward 'as-is' bolt-in that'll work is to transplant buckets from another Tacoma. Within same eras, the separate buckets use the same mounting bolt pattern as the 60/40's you currently have.
Anything else will require some modifications / drilling / fabbing.
Some 4Runner and allegedly some Celica seats can line up on 3 of the 4 Tacoma mounting holes. You'll have to go free-form to connect the 4th.
In general, anything that can physically fit in your cab will do... The hard part, however, isn't the seats themselves - it's the mounting.....
Old Oct 15, 2005 | 07:01 PM
dfoxengr's Avatar
yeah a little modification is fine, but i dont want to make new rails.
Old Oct 15, 2005 | 07:02 PM
dfoxengr's Avatar
3 of the 4 is fine. ive done that with integra into civics before so thats no big deal.
what are you guys using for harness shoulder strap mounts too?
Old Oct 18, 2005 | 10:03 AM
dfoxengr's Avatar
anyone have answers?
Old Oct 19, 2005 | 02:33 AM
EnolaGaia's Avatar
Shoulder harness straps should be anchored no more than 10 - 15 degrees above / below a horizontal line extending straight back from the tops of your shoulders. To achieve this in a Taco, your options are: (1) install roll cage; (2) install harness bar; or (3) figure out an adequate anchoring strategy using the rear cab wall.
Some folks go ahead and anchor shoulder harnesses downward to the floor (sometimes even to the seat's own mounting bolts). This is a VERY BAD approach. In the event of a frontal impact, downward-anchored straps will induce a compression effect that can easily damage your spine.
Old Oct 19, 2005 | 02:49 AM
rocket's Avatar
Theres LOTS of information on this subject if you use the 'search' option...
Old Oct 19, 2005 | 03:49 AM
dfoxengr's Avatar
yeah i know that, and ill use a bar. just wondering what everyone else uses
kouki420
Sep 2, 2015 11:42 AM
TDonkey
Jul 26, 2015 10:14 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
icentropy
Jul 9, 2015 02:12 PM
garagespace
Jul 9, 2015 08:37 AM
