New Mod: 3.4L TB Bore Mod, “O” Gasket Mod, and PCV Breather Mod – with pics
Old Mar 2, 2004 | 06:12 PM
  #101
keisur's Avatar
Originally Posted by 99' 4runner
Hey christian,
I was wondering if 99' 4runner 2wd have that "O" Gasket or the D gasket?
a good rule of thumb on that is that if the gasket is metal, it is the "D" or restricted one. if it is paper than more than likely it's an "O." you can see part of the gasket sticking out between the TB and the manifold without dismantling it. check that out first.
Old Mar 2, 2004 | 06:46 PM
  #102
mr4x403's Avatar
nice writeup and nice info too. i always enjoy reading about what mod is next. i am too interested in the O gasket when you do get them.
Old Mar 2, 2004 | 07:33 PM
  #103
rimpainter.com's Avatar
I think I will get more. The demand is starting to climb again.
Justin-
Has anyone asked you about your avitar yet? Holy cow!
Old Mar 2, 2004 | 08:20 PM
  #104
keisur's Avatar
I still have yet to install mine.
Old Mar 2, 2004 | 10:54 PM
  #105
Birdman's Avatar
I believe the downside of this is that the blowby or by products of the combustion process that make it past your piston rings are not being sucked out of the crankcase and reintroduced back into the intake for reburning. The net effect of this could be an increased buildup of the harmful chemmical components in your oil, which are responsible for the break down of the oil's lubricating properties. I know some of it is being pushed out of the new breather, and this is how it was done in the old days, however, I believe the PCV process is more effecient at evacuating the gasses and reducing the rate of introduciton into your oil. IMHO
Old Mar 3, 2004 | 04:38 AM
  #106
The PCV mod is no longer recommended. What's the matter, you didnt want to read 5 pages of posts?
You are correct, with the PCV mod, I could smell gasses that did not go through the Cat. In other words, it stunk.
Old Mar 3, 2004 | 06:51 PM
  #107
derrick92130's Avatar
Originally Posted by ravencr
Is the part number 22275-20010 for the TRD supplied gasket that comes with the Supercharger or is this another O gasket that you guys found.
Chris
Not sure if anyone found the right gasket number or not. I ordered a couple from my dealer using the TRD partnumber from my 2nd gen S/C and have one lying in front of me. The TRD Gasket Part Number is 00602-17620-032. I thought someone might run across this thread and look for the right number. I paid $6.50 each from the dealer.
Old Mar 3, 2004 | 07:38 PM
  #108
Tacoma Dude's Avatar
Thanks for the update, Christian.
I saw a couple of those fuel filters a few days ago and was wondering how that mod was treating you.
Old Oct 27, 2004 | 06:59 PM
  #109
kevin444's Avatar
BUmp for good thread hey christian got any more gaskets?
Old Oct 27, 2004 | 08:26 PM
  #110
Oh yeah, I promised a bunch of people I would get some. Let me look into that again.
I think I can do $4 each. But let me check.
Old Oct 27, 2004 | 09:24 PM
  #111
humanoid's Avatar
Thanks, man! Been waiting!
Old Oct 27, 2004 | 10:39 PM
  #112
kevin444's Avatar
Yeah i was trying to figure out what the o gasket is till i read this humungous thread. Hmm damn its raining outside so i havent verified if i have the d gasket. Hey christian i like to see some dyno runs with your tricked out NA setup..
Old Oct 28, 2004 | 04:59 AM
  #113
Yeah, me too. But I wouldn't expect a real nice looking dyno slip. I think the mods performed thus far have only bumped my HP + TQ in a very small RPM range - I am guessing somewhere between 3600 ~ 4600. Unlike a properly tuned SC'd 5VZ, which should show a nice linear HP increase once the parasitic drag of the SC'r is overcome.
Here is the order of power enhancements, in order of the largest gain IMO:
1. Headers
2. Gear ratio change (4.10 - 4.30)
3. Deckplate mod
4. Exhaust (hacked out stock muffler, welded in glasspack)
5. ISR mod
6. TB bore
7. Type O gasket mod
5 - 7 were not noticeable by the seat of my pants.
Old Nov 20, 2004 | 12:05 PM
  #114
Bump so Mark can see the pics easier. Good luck Mark!
Old Nov 20, 2004 | 12:09 PM
  #115
midiwall's Avatar
THANKS MAN!
Old Nov 20, 2004 | 02:54 PM
  #116
midiwall's Avatar
and.....
DONE!
There're a lot of mods on my truck, and I never expected to feel something this slight (and I don't), but knowing that lip is gone gives me a bit of a smile on my face.
What I did do to get more oomph during this pass under my hood was to... realize that my throttle cable had about 1/4" of slack in it. oops.
Thanks for the idea Christian!
Old Nov 20, 2004 | 04:31 PM
  #117
Awesome Mark! Now, go smoke some ricers!
Old Nov 20, 2004 | 07:22 PM
  #118
4RUNR's Avatar
Guest
PCV Breather Mod
I do not recommend the PCV mod. 11.20.04
Why?
Old Nov 20, 2004 | 07:25 PM
  #119
2001Millrunner's Avatar
Originally Posted by 4RUNR
Why?
it stinks
Old Nov 20, 2004 | 07:45 PM
  #120
Literally!
