New inner tie rod ends - one not like the other.
Old Jun 7, 2019 | 04:06 PM
jukeit's Avatar
Hi - I'm replacing some parts on the front of my 99 4runner. I have two new inner tie rod ends (both Import Direct). One, that I've already installed, moves around with minimal effort applied. The other one, not installed takes a lot of force to move. If I hit it against the ground, it will move a little bit. Maybe it just needs to be "broken in". The concern is that I have two new parts that have vastly different beginning "behavior". Any thoughts on which is more normal and if I should avoid using one or the other is appreciated.
Thanks
Old Jun 7, 2019 | 06:00 PM
jukeit's Avatar
Just watched some youtube, and it looks like the one that doesn't move is the good one. The one that moves with minimal effort is likely no good.
Old Jun 8, 2019 | 03:49 AM
aowRS's Avatar
The joint should be pretty stiff when new.
Andreas
icerunner
67
Jan 9, 2022 06:38 PM
83yotarox
Jul 20, 2014 01:17 PM
defyota
Dec 21, 2008 07:40 AM
MTL_4runner
18
Dec 1, 2004 11:44 AM
Dr. Zhivago
28
Nov 5, 2003 07:48 PM
