New Idea on How to Run 2 Topouts...
Old Nov 1, 2007 | 08:07 AM
Nate08's Avatar
Instead of limiting straps...how about stacking washers and bringing up the bumpstomps of the lower control arm? Seems like it would serve the same purpose?
Old Nov 1, 2007 | 04:24 PM
rocktown's Avatar
Two top out spacers are bad because of excessive droop, which creates extreme cv angles and thus breakage. Using limiting straps lets you control how much the suspension droops. Raising the bumpstops on the lower arms would just reduce suspension travel, that wouldnt do anything to prevent excessive droop.
Old Nov 1, 2007 | 04:37 PM
Nate08's Avatar
Define your term of "droop".
Old Nov 1, 2007 | 04:50 PM
KZN185W's Avatar
Droop is the downward travel of the suspension.
The stacked washers that you mentioned doesn't limit the downward travel. It can only limit the upward travel. A limiting strap is needed to limit the downward travel.
hth
Old Nov 1, 2007 | 06:09 PM
waskillywabbit's Avatar
This has been discussed several times before on this forum and it is a BAD idea.
Old Nov 2, 2007 | 03:30 AM
Nate08's Avatar
There just seems to be alot of people running 2.5" or 3" spacers. I don't see how 2 topouts could be worse.
Old Nov 2, 2007 | 06:12 AM
Bighead's Avatar
I assume you are talking about the Daystar-style lift spacers. Those spacers are providing the lift and are not being used in conjunction with a lift spring. They are on top of a stock spring.
Old Nov 2, 2007 | 07:25 AM
SLC97SR5's Avatar
You should try wheeling it hard at full lock with 2 Top-outs and lots of traction. Make sure to bring you hubn socket and a new CV.
Old Nov 2, 2007 | 08:03 AM
Nate08's Avatar
[QUOTE=Bighead;50657666]I assume you are talking about the Daystar-style lift spacers. Those spacers are providing the lift and are not being used in conjunction with a lift spring. They are on top of a stock spring.[/QUOTE
Gotcha, thanks for clearing it up.
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
88runnergomas
Jul 9, 2015 01:12 PM
