new fuel filter,,,,is it possible?!!!!!
Old Aug 22, 2004 | 12:44 AM
  #61
Maddog's Avatar
Well its about time scofco ,its been on the to do list forever hasnt it.
Old Aug 22, 2004 | 06:13 AM
  #62
Beerdrinker's Avatar
Hi all just joined Yotatechjust bought a 99 4runner. Looking forward to offroading again, after a long absence, anyway. on my old Toyota 4x4 what I did after I replacing the stock fuel filter, I realized this is a pia to do. so I found an easy to reach place in the fuel line along the frame and added an in line fuel filter. Cut out a section of the steel line and put in a fuel filter that uses the rubber hoses and hose clamps. Now all I have to do is replace that one and leave the stock one alone.
Old Aug 22, 2004 | 06:34 AM
  #63
shazaam's Avatar
If the stock one is clogged .. you really haven't done anything beneficial by adding another one
Old Aug 22, 2004 | 08:35 AM
  #64
MvCrash's Avatar
Greetings,
I had a 22RE. CHanged the filter and never wanted to do that again. I moved the thing to the top of the inside fender well. Small about of tubing, some fittings and poof, no more headaches.
I also change the fuel filters every 10,000 on any fuel injected engine. The pressure is important to the injectors. Once moved, it easier than changing the oil.
Also put a small amount of anti-seize compound on the fittings, next time they wall come out with no trouble at all.
MvCrash
Old Aug 22, 2004 | 08:42 AM
  #65
Scofco's Avatar
A few months
Doing the O2 sensor today, and throwing on some new plug wires.
Old Aug 22, 2004 | 09:06 AM
  #66
no no I added the extra one AFTER I replaced the stock one.
Old Jan 21, 2006 | 02:48 PM
  #67
Platypus1's Avatar
okay, I must say that Maddogs post proved invaluable to me while changing my Fuel filter. I started out using an open end 14mm wrench and damn near rounded off the front fuel line bolt. I checked out this post and found out about "flare wrenches". I did an image search to find out what they look like and bought a 3 piece set for $8 at Pep Boys. I must say...dont even attempt this job until you have a 14mm flare, it makes the world soooo much easier. I also used the large nut on the back of the filter as my pressure point (much more leverage) and simply held the flare while it was locked on at the front. Easy money! I did not have to mess with the cross member at all.
Long live MADDOG! lol
and yes, the trottle response did improve upon filter change. I re-set the computer as well, though I dont know if it was necessary or not.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
pyramid
Jul 30, 2015 10:05 AM
ddg71
Jul 24, 2015 01:24 PM
Fundy Rider
Jul 16, 2015 01:35 AM
