Need Toyota 22re Help! Pics Inside!
Old Apr 5, 2004 | 03:31 PM
bigjim's Avatar
I just picked up an 87 4runner with a 22re. cylinder head gasket was blown and the previous owner had taken it apart. well i had the head rebuilt and i started putting it back together. ive gotten it almost finished but have come to a problem. there is a smog pipe that gets bolted to the exaust manifold, from there it bolts to a 2nd pipe and seems to have to hook around to the left around the back of the head and seems to bolt some where on the intake, but i have found no place for it to go. this has been holding me up for days! anyone have an idea ,or can some one look at their truck and give me some direction? maybe im missing some parts since the distributor was missing and i had to buy a new one. any help is APPRECIATED greatly! thanks alot, jim
Old Apr 5, 2004 | 05:23 PM
DavidA's Avatar
I found a reference to it in my Haynes repair manual on Page 188.
It appears to be part of the AS (Air Suction) System. That end attaches to a AS Reed Valve. The AS system draws air into the exhaust manifold to accelerate Oxidateion, using vacuum generated by the exhaust pulsation in the exhaust manifold.
If you want a picture of it then I will scan it in for you. There is not much to see. That end attaches to the AS Reed valve..then over to a VSV, then to some vacuum switch on the side of the engine.
Another hose comes off that Reed valve, then over the engine to a Resonator and then it looks like into the air filter assembly.
Let me know, maybe that can get you started.
Old Apr 5, 2004 | 05:51 PM
DavidA's Avatar
Woot!!! I found the diagram online with an explanation for you.
Link to Diagram/PDF
That should help you finish it!
Old Apr 5, 2004 | 06:28 PM
CrazyDiamond's Avatar
Link to Diagram/PDF
Yep. It's part of the Air Suction system. If I didn't have to get an emissions check, I'd leave the whole thing off and block off the holes :-)
To find where it bolts, stand at your passenger side front fender, facing the intake manifold. Follow the intake runner for the rear (#4) cylinder with your hand - almost brushing the firewall. Right at the very bottom of the curving runner, you'll feel 4 bolts. 2 hold the reed valve to the bottom of the intake and 2 are the bolts that bolt the hard pipe to the reed valve. They are a bitch to get wrenches on, so have an assortment of shortie-style wrenches on hand.
Let me know if this helps.
Old Apr 5, 2004 | 07:07 PM
bigjim's Avatar
you guys are awsome..ill see what i can find tomarrow when its light outside. thanks..ill let you know my results tomarrow! thanks again, jim
Old Apr 5, 2004 | 07:08 PM
bigjim's Avatar
man...link doesnt work...i planned to print the pic too..let me know if you can send me that via e-mail. thanks jim
Old Apr 5, 2004 | 07:46 PM
bigjim's Avatar
looked at the site and cant find the info, link doesnt work. maybe i have to be a member?
Old Apr 6, 2004 | 07:32 AM
DavidA's Avatar
That link won't work unless you have Adobe Reader installed. Go to www.adobe.com and download the free reader. It will take a few minutes for the document to download...longer if you have dialup.
Let me know.
Old Apr 6, 2004 | 09:05 AM
bigjim's Avatar
i have it, but redownloaded it and it still wont read. i just get a red box. man this sucks!
Old Apr 6, 2004 | 09:37 AM
DavidA's Avatar
Jim, you have a fax number? If so then I will fax it asap.
I just printed it off.
Old Apr 6, 2004 | 04:07 PM
DavidA's Avatar
Fax sent...let me know if you did not get it and I will send it again.
Old Apr 6, 2004 | 05:27 PM
Arnold's Avatar
Did 86-87 22RE's even come w/ an air suction/injection system? I thought only 22R's had 'em? IIRC, my '86 FSM only showed the system on the carb and not the EFI. Could be wrong though. Unfortunately, I don't have the FSM w/ me to verify.
Old Apr 7, 2004 | 04:26 AM
foxtrapper's Avatar
Guest
I've got three 86 22RE's, and none of them have this circuit.
Old Apr 7, 2004 | 04:51 PM
barkeywayne's Avatar
My 86 22RE doesn't have those tubes either, it has plates on the exhaust manifold that blocks the holes. My 84 22R does have the tubes.
Old Apr 7, 2004 | 07:08 PM
DavidA's Avatar
He may have a late 1987 model of the engine. Per my Hayne's guide it states that this was typical of the 1988 engine models and later.
6th Gear
19
Dec 10, 2019 07:31 AM
warrenjcarlson
Jul 22, 2016 11:47 AM
DacodaYota
Sep 2, 2015 02:13 PM
JaredL
Jun 16, 2015 04:47 PM
