Need Part Number/Help!
Yesterday I went over a cattleguard and my tire blew out. Upon removal of the tire I discovered that there were no bolts holding the suspension arm on (as pictured below) anyway I was wondering if anyone knew the part numbers for the bolt or what I can do to fix it. especially since My summer job is on Lake Powell where I currently am and the nearest Stealership is 220 miles away. I was about 20 miles away from home and when it happened and managed to take my belt and wrap it around the suspension arm and axel to keep it pinned to the axel so I could drive back. I have to get a new tire as well cause I'm driving on the spare. I just want to get it fixed so I can drive the 200 miles to get a new tire. So what should I do?!
Also shes a 98 2wd 4runner automatic with rear drum brakes
Thanks in advance
-Hunter
Bolts are missing in this picture
Bolts are here in this one as its the drivers side instead and didnt have any issues
Thanks in advance
-Hunter
It looks like you mean there is no bolt holding the shock absorber on. It's hard to be sure in the picture due to the back lighting...
The bolt that holds the bottom end of the shock absorber on is 91619-G1222, the big washer is 90948-03020, and the rubber bushing in there is 90385-19007.
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
FS[GreatLakes]: 22RE performance and stock parts (pic heavy)
May 20, 2016 10:27 AM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
Jul 9, 2015 02:34 PM
