need help wiring after engine rebuild
I have just finished installing a rebuilt 22-re into my 93 4X4 pickup. Problem is I am finishing up but can't figure out where a wire goes. The wires are three brown wires that come out of the wiring harness under the fuel injection. They are all bundled up with black electrical tape and end in a single lead that looks like it might be ground as a bolt would go through the lead. If it is a ground there is nothing but aluminum in the general vicinity unless I go across to the fender.
Any help with this would be greatly appreciated.
Do you have any grounds going to head/block to frame? my 22R has three separate ones. Can you find where it is coming from? Just giving you some ideas. Maybe some one with a 93 can help if you have a picture?
HTH
Nathan
HTH
Nathan
To me it sounds like you're talking about the ground wire that attaches under the #2 intake rail. There is a steel rod coming from the engine mount to the intake. It goes on the bolt that holds all that together.
steve miller
Oct 10, 2015 01:40 AM
