Need Help! Tacoma Front End Question
Old May 14, 2009 | 05:06 PM
i_love_tacos's Avatar
Ok so i was wheelin one day and when i was tryin to climb this huge ledge i heard some metal breakage noises and lost 4WD. I thought it was the driver side CV axle and so i replaced both sides. Turns out they were fine and still no 4WD. Could it be the rind and pinon? i hear no weird noises at all while drving and when put into 4WD.
This is my first time breakin sumthin so I am a bit lost.
thanx...
Old May 14, 2009 | 06:04 PM
dport's Avatar
Guest
Have you checked your driveshaft U-joints?
Old May 14, 2009 | 07:49 PM
BajaRunner's Avatar
How are you certain you have no 4wd? No drive to the axles or just no 4wd light?
If the ring or pinion were screwed up you'd know.... unless the teeth on the ring were completely sheared off that the pinion is just sitting there spinning!
Old May 14, 2009 | 07:55 PM
u-joints are fine.
i do know the driveshaft does spin when 4WD is engaged. front wheels dont move while the rear is. tested it by going up a hill as slow as possible to the point where the rear wheels are digging into the dirt.
Old May 14, 2009 | 08:25 PM
no drive to the axles.
Old May 15, 2009 | 05:58 PM
talked to a mechanic and he suggested the spider gears are gone. sounds about right. whatcha all think?
Old May 15, 2009 | 06:10 PM
Tacoclimber's Avatar
One way to find out... break er open and have a look. If it is the spiders, you might think about re-gearing at this point...
Old May 16, 2009 | 12:33 AM
good idea but im gonna wait till i get a locker to install and just get rid of the spider gears. not sure about regrearing at this point. 4.10s are doing ok rolling the 33s. im going to regear when i do a SAS at the end of the year.
Old May 16, 2009 | 04:25 PM
wunbigtacoma's Avatar
if anything drain some of the fliud if their is metal?
Old May 18, 2009 | 07:17 PM
yup it glimmerd and was nice and shiny oil. haha
time for the locker.
one of the little gears must be sittin in pieces at the bottom of the diff.
can it do that?
lledwod
Aug 30, 2016 01:03 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
toyoda8488
Jul 5, 2015 10:18 PM
