Need Help...Stuck spark plug wires
Old Mar 11, 2007 | 07:39 PM
soljah's Avatar
Can anyone suggest a method for removing stuck spark plug wires. The three wires/spark plug wire boots on the drivers side are stuck and do not seem to want to come out. When I purchased my rig a few years ago, I replaced the wires with some thicker Magnecor spark plug wires. At that time, they were very easy to remove and replace.
I have tried to pull them out with all my strength and cannot get them out. Due to me pulling on them, I have torn the spark plug wire boot on one of the wires. I have purchased a spark plug wire remover tool from MAC for better gription and this has not helped at all. Any suggestions on what else I could try?
Old Mar 11, 2007 | 07:42 PM
DeathCougar's Avatar
Welcome to the downfall of aftermarket plugwires. Just yank them out of there, and replace with a factory set. You will thank yourself in the future.
If you have torn a plug boot, you should replace it anyways, and the only way they sell these wires is in a set.
Old Mar 12, 2007 | 05:33 AM
MTL_4runner's Avatar
Thicker wires doesn't equal better.
Get those wires off (rip them if you have to) and buy a new set at the dealer.
You can use a bit of dielectric grease on the inside of the boot next time to make this process easier.
Old Mar 12, 2007 | 10:28 PM
leonardator's Avatar
oxy-acetylene???? btw, what is a deckplate mod???
Old Mar 12, 2007 | 10:30 PM
Acetylene...as in a torch? how exaclty do you propose using a cutting torch to remove spark plug wires?
As for a deckplate mod....SEARCH for it. I bet there is 20 threads and countless articles devoted to this mod.
Old Mar 12, 2007 | 10:57 PM
Elton's Avatar
https://www.yotatech.com/forums/f130/deckplate-mod-75169/
sandyota
Feb 4, 2021 11:16 AM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
smiley52
Jul 11, 2015 05:16 AM
88runnergomas
Jul 9, 2015 01:12 PM
