Need help fast! Re: gears & locker scenarios & prices
Old Dec 28, 2006 | 04:22 PM
98LimitedCustomized's Avatar
Okay I've got a 98 4Runner with 4.10's and am running 32" tall tires. I'm taking off on a LONG road trip and am passing some yards that have 4.30 rear ends with lockers as well as 4.30 fronts as well as just diffs. The rear axle is $460, front is $350, and $150 for just the front diff. I'm hoping I can sell my old axles.
But then I got to thinking... How far off would I be in price from a set of new 4:56's? How about with an ARB or two installed. Thing is, I can do the complete axles, but not gears and or lockers. I'm sluggish now and think my mileage could go back up, and I'd like to move to 33's in the future. Can I get your opinions, experiences, and maybe some $$ figures as well. I'm leaving for this trip in the morning so I need to decide in the next 4 hours!
Old Dec 28, 2006 | 04:32 PM
RustBucket's Avatar
It depends mostly on what you want to do with your 4Runner... lots of wheeling? Just occasionally?
Old Dec 28, 2006 | 04:37 PM
Tanto's Avatar
If 33"+ tires are in the distant future for you, 4.30 should be fine and you'll save some money while you're at it. Probably enough to put an ARB in the rear if you really wanted to.
Old Dec 28, 2006 | 04:44 PM
rimpainter.com's Avatar
Go for the full swap, front and rear. Sure it took some work, but in the end I am very happy I did it. Be prepared for the front swap though, that my friend, is not fun.
You should be able to sell your stock 4.10's for a little cash as well.
Old Dec 28, 2006 | 08:17 PM
Jonathan's Avatar
Definetly get the entire rear axle if you can and not just the third member, that way you won't have to modify the axle housing like I did. Pick up the front diff as well, that price is very fair for a 4.30 front. If you can, grab the ECU and all the wires as well or take the easy way out and order a wiring kit from Inchworm.
It'll take a good bit more money to get the gears and ARB's installed, because you have to buy the gears and the lockers then have someone set up the gears and install the lockers, plus the air compressor for the lockers. I wouldn't set up gears and then go back and set up lockers later because it wouldn't be cost effective, seeing that you would have to open everything back up twice to do each install. My rig drives so much better now with the 285's and 4.30's then when I just had the 4.10's.
Old Dec 28, 2006 | 11:50 PM
Thank you! That's kind of what I was thinking, but it's a tough call on the "still in college budget".
Old Dec 29, 2006 | 06:04 AM
KyleT's Avatar
I just put in 4.88's and have 295's. it drives a ton better than before with 4.10's
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
coffey50
Jul 28, 2015 10:55 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
