Need Help ASAP-Speed Sensor Location?
Old Mar 11, 2006 | 08:27 AM
SteveO's Avatar
Originally Posted by BruceTS
Steve, on the manual transmissions, the ADD system is mechanical, in the sense is doesn't go through a computer. there's 2 switches on the transfer case, one to detect 4H and the other for 4L. When switched into 4h it activated a relay to switch the vaccum relays. If you need a diagram I can get it for you.
I can't speak to the manual transmissoins, but only what I have found for the Automatic crowd and Multi-mode transfer case, such as in the Limited Transfer case "VZN185L-GKPZKA". That would be great to have more information (your diagrams) from what you have.....Thanks
As for the speed sensor, see if you can feed the signal directly to the ABS computer from the tramsmission sensor. You may have to build a signal amplifier/splitter, so the 1.40 - 1.80k ohms of the sensors remains constant. Just not too sure how sensitive the input signal to the ABS cpu has to be, you may just need to splice them directly together, then tie all 4 inputs together, but I still would put in diodes to prevent any feedback signal.
From all the wiring diagrams that I have seen, the input to the ECU is the same, between the T-case connection and the automatic transmission.
The speed sensors at are based on Pulses, such as found on an ocilliscope(sp?), as opposed to the speedo on the transmission which is based on voltage. However, I have considred this, and indeed, I do want to be careful so I don't blow out the circuits for the speedo console. Still researching.....
Old Mar 11, 2006 | 10:07 AM
BruceTS's Avatar
the waveform is created the same way, by moving a piece of metal between a magnet it causes a small votage pulse. This causes the square wave you see on a scope, so it should be useable. If you connect to the ABS computer all that could happen is you fry it, which your not using right now anyways.
Old Mar 11, 2006 | 11:18 AM
SteveO's Avatar
.........all that could happen is you fry it......
LOL, yeah, I just hope to not fry anything else in the process. Let me know when you can get the diagram posted somewhere.
Thanks
Old Mar 11, 2006 | 05:32 PM
dragr1's Avatar
Wow, it's so nice to have a speedo that is accurate again. I even replaced the MAF sensor today and wow again-it's so nice to have a motor that pulls through it's rev range instead of just stumbling at heavy throttle!
Old Mar 11, 2006 | 05:58 PM
  #25
SteveO's Avatar
Schaefer I hope to have not offended you with my above comment on the ABS issue. With so many different variations of transfer cases and transmissions, it would definitly be diffcult to stay on top of it all.
Great job your research and documentation.
Old Mar 11, 2006 | 09:51 PM
  #26
Albuquerque Jim's Avatar
[Hyjack on] A new MAF? Did it really make a huge difference? How much was it? [Hyjack off]
Old Mar 12, 2006 | 04:48 AM
  #27
dragr1's Avatar
Well, I've had sensor issues for a while. I replaced the MAF once already with a junkyard unit-maybe 2 years ago or so. When I pulled that one out yesterday, it came out in 2 pieces-yikes.
The check engine light has thrown the same P0171 code several times over the last year. It would run fine at light throttle, but at heavy throttle it was very sluggish and almost felt like something was holding it back from revving-running rich. So yesterday I just got tired of it, had a diagnostic run at Toyota and had them watch the fuel curve while it was running and sure enough mechanic said MAF. I was like dangit not again. He then told me that this was such a common problem that Toyota did a slight re-design on that part a while back. Sure enough, it had a different part #. He said everyone that had this new part number MAF had not been back with the same problem anymore. So I coughed up the $116 for the part (would have been $145 w/o the TLCA discount) and picked up a new air filter while I was at it.
Went home to install it and forgot that last time I swapped the MAF that I had boogered up the screws. So I had to remove the airbox and tap the screws out. Made a trip to Home Depot and found some screws that would work and can be taken off with a wrench now. Installed with the battery disconnected. Drove around a bit and then tried out full throttle and it was so much better-smoother and it pulled through the rev range where before it would just stumble.
Old Apr 1, 2006 | 06:27 AM
  #28
sschaefer3's Avatar
Bruce is correct. After a bunch of head scratching, a few curse words, calling Superlift on the phone only to realize they have no clue, it is installed and working. The wire I needed did in fact come off of the abs computer, it was even the same color as Superlift said it would be-this would have been a really simple install if Superlift would of had instructions that were correct and tech guys that actually knew something.
Incidentally, a master Toyota mechanic friend of mine did verify that we had the correct wire before it was cut.
Thanks for the help guys! Bruce I owe you one!
Incidentally on the home, the check engine light came on, but I think it is unrelated and should be my re-occuring P0136, or was it P0171, hell I can't remember, but Autozone will tell me tomorrow.
Ok which wire was it? The Speedo on this 96 I SAS'd does not work obviously. So without a doubt the 2.7 is far easier to swap. I need a place to run the wires from a t-case sender to and I'm willing to bet the wire you cut or identifed is it.
What wire is it? I'll call Rubicon Express on Monday, I got wraped up in wrapping the swap up, it's done.
Old Apr 1, 2006 | 07:22 AM
  #29
dragr1's Avatar
It was the grey wire with a blue tracer line on the abs ecu on the passengers side front kick panel.
Old Apr 2, 2006 | 07:18 AM
  #30
sschaefer3's Avatar
Thanks. I got the speedo working a different way, but this is good to know.
Old Apr 2, 2006 | 07:31 AM
  #31
dragr1's Avatar
How did you get it working?
taller1
Nov 13, 2018 02:34 PM
4x4-runner
Aug 30, 2015 08:55 AM
4x4-runner
Aug 2, 2015 09:24 AM
jetspeedz
Jul 13, 2015 09:32 PM
