need help asap
Old May 13, 2018 | 06:19 PM
cbr600rx7's Avatar
need help asap
Need help asap guys. Working on a 1999 Tacoma with factory manual hubs. I had a front diff issue and picked up a front and rear diff set with 4.56 gears and installed the rear with no problem. Now I am working on the front and assumed I could just change the diff tube that runs to the passenger side out from the non add to the add and be done. Well of course it's never that easy and where the tube meets the diff isn't going to work. My main question is will the factory manual hub CV shafts slide into the ADD diff? I could just use a hose clamp to lock the ADD for the time being. Really need to get this truck back on the road.
Old May 15, 2018 | 07:55 AM
Jomoka's Avatar
My wife put a set of Tacoma manual hubs/axles onto her ADD equipped 4Runner. The manual CV shafts work perfectly with the ADD diff. The ADD part is a bit unnecessary, but (as long as it still works) is not an issue.
grafix43
10
May 25, 2004 08:48 PM
legend4ever
Mar 28, 2004 06:33 PM
Debra
10
Jan 31, 2004 08:15 AM
jacksonpt
21
Jun 29, 2003 07:57 AM
Stump1883
Dec 11, 2002 11:17 AM
