my new 2000 4runner what kind of service should I have done
I finally found and bought a 4runner locally. Its a 2000 limited 4x4 with the diff lock. It has has 95,000 miles. My question is what kind of service stuff should I do right now?
I've got the same ride. Knowing what I know now, I would(if your mechanical), pull off the tranny pan and clean it and the filter....replace your rear inner axle seals with napa seals(make sure the napa seals are green around the outer edges), grease your drivetrain ujoints, put the beefier tundra brakes and calipers on the front....i'll update as I find stuff to be fixed!
Don't let them scare you, they are just grumpy.
The search on this site is totally screwed up, I have been using it for a few months but i still can't even find threads i KNOW are there, even ones I posted. Just try searching but here is a thread i had about the same thing...
https://www.yotatech.com/forums/f2/what-should-i-do-what-should-mech-do-my-200-4runner-113162/
I'm going to do most of the stuff that is recomended for the 90,000 mile service.
Congrats, that's the first thing I thought about when I got my used 99 SR5 in March. Maybe the car is in good condition, but I just feel there must be something that can be repaired since it's a used vehicle. my toyota dealership told me to bring it back when I get my 1st oil change.
https://www.yotatech.com/forums/showthread.php?t=113162
i thought this was helpful, found it in the write-ups section:
https://www.yotatech.com/forums/showthread.php?t=76317
deals with fluids mostly but also mentions some other helpful things to check down the line, and with 90k it's stuff you might want to look at.
when i got my '98 at 62k i had the coolant flushed for starters and i'm in the process of converting over to all amsoil synthetic fluids. i'm putting my tundra breaks on in a couple weeks and i'll flush out the breaks with new toyota fluid when i do it. i'm not a mechanic so i'm sure there are plenty of other things to look at drivetrain-wise, but also check your belts and hoses just to be safe. just a few things off the top of my head.
patrick
patrick
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
