mt/r on 1st gen
Old May 12, 2003 | 06:51 PM
descendents's Avatar
mt/r on 1st gen
whats the biggest size of mt/r i can fit on a stock 1st gen... 265/75 MT/R's? should i not go that big? im running 235/75/15's now.. thanks for the responses in advance
kelly
Old May 12, 2003 | 07:27 PM
Victor's Avatar
Is that tire size on a 15 or 16" wheel? If it is 16 - Crank your torsion bars and then go with a 1.5" shackle lift in the back and you can fit those. What engine, tranny, gear ratios you have?
If it is the 15 inch wheel size then it should fit stock.
Old May 12, 2003 | 09:48 PM
i have 15 inch rims, could i go any bigger??
Old May 13, 2003 | 04:48 AM
Victor's Avatar
You can go with a 32x11.50 on your wheels. That is wider than what I'm using but the same height. Just do the modest lift I mentioned.
Old May 13, 2003 | 05:07 AM
beachtaco's Avatar
if you going to run the stock steel rim which is a 15x6, then 235/75R15 is the largest tire. if it's the stock alloy rim which is a 15x7, then you can run a 31x10.50R15.
if you aftermarket rims, then you should check on the width of the rim. and go by this... (stock, no lift)
15x6 - 235/75R15
15x7, 15x8, or 15x10 - 31x10.50R15
you probably can fit a 32x11.50R15 but you'll rub some.
Old May 13, 2003 | 08:16 AM
jx94148's Avatar
I ran 31x10.5x15s on 15x6 wheels for years. You do not need wider wheels to run 31x10.5s.
kawazx636
Oct 6, 2021 03:03 PM
Badlander
Oct 10, 2015 08:05 PM
voiddweller
Oct 2, 2015 07:47 AM
Toys4parts
Sep 26, 2015 01:56 PM
Project90
Sep 24, 2015 11:40 PM
