MPG things to check
Old May 2, 2004 | 04:47 PM
miketerrizzi's Avatar
MPG things to check
Yeahhh last tank i was got 12.5 mpg and i didnt do anything to the engine. I recently have been getting bad gas mileage but i aint running around town flooring it , i do alot of high way driving so I was wondering things i should look at before I have someone else take a look at it. I can do almost anything a mechanic would be able to do but I just cant figure out what might be broken. I dont have a check engine lite.
Old May 2, 2004 | 05:18 PM
AF1's Avatar
AF1
If its a 3.0 sounds normal to me....here is what I have done to my truck and I was getting 11 to 12 MPG.
1. Changed HG
2. Dynomax 21/4 exhaust....new cat also
3. Timing belt, water pump, idler pully, tensioner
4. sparkplugs, cap & Rotor, new wires
5. Fuel filter
6. O2 sensor (Denso)
7. Brakes
8. Tranny fluid, both diffs, trans case
9. Anti freeze flush
10. cleaned Throttle body
11. Tires at 38 psi
12. changed to Mobil 1 synthetic...engine fluch
13. new airfilter
14. PCV valve
15. front end alignment
16. new tires
17, all new drive belts
18. Getting rdy to put on manual locking hubs, new rotors, rebuilt brake calipers..one of mine are sticking
19. also lube drive shaft and all other lube points
This was all done in the last 2 months.....Do you want to know what my MPG is now.....11 to 12 MPG.....
Old May 2, 2004 | 05:37 PM
Amkeer's Avatar
I get 15 in stop and go city driving, real crappy driving. On the highway 21 MPG at 75 MPH. I use maintenance dose of fuel additives every other tank, 1.5 oz. to 10 gallons.
The government changed the fuel requirements so we are all getting 5-10% drop in MPG. Isn't it great that we get gouged for a .55 cents a gallon tax and its compounded by higher prices and poorer quality.
Old May 2, 2004 | 06:35 PM
bike4miles's Avatar
I used to get 16 city/4x4 and 19 highway with my 89 3.0 with stock tires. I replaced my O2 sensor on my 91 4runner and picked up 2 mpg FYI so you might consider that. It had 150K miles on it and I was reluctant to drop the $150 but I think it has paid for it's self already.
Old May 2, 2004 | 07:20 PM
calg3's Avatar
What air pressure are you running with in your tires? How does the air filter look?
Old May 3, 2004 | 01:27 PM
okay hereeeee we go
I recently did wire and plugs,injector cleaner,o2, air filter, fuel filter. I just finished the o2 today, the bolts that hold it on were soo rusted and heatted to death. So I dont know if it improved anything yet. Is there anything I am missing
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
ryerye13
Jul 14, 2015 08:27 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
