Mounting a Cobra WXSTII CB
Old Feb 24, 2004 | 04:54 PM
hpinson's Avatar
Hi. I have just mounted a Cobra 18 WX ST II CB in my 95 4Runner and have encountered two problems. This seems to be a common CB in a 4Runner, so I guess maybe I'm not alone...
When the CB is mounted in the lower pocket, there is not quite enough room
behind it to accommodate the coax cable faster. It butts up
against a white plastic housing behind the radio. I installed a right-angle
adaptor, but the radio is still not quite flush in front, even when I jam it in. Any suggestions? Remount the coax mount male on the radio itself, to the left or right?
Also, the two steel Toyota radio mounting brackets (L and R) do not match the mount points on the radio. I ended up duct-taping the radio to the stero
above, which is a pretty embarassing solution. Any thoughts on how to mount this radio to metal?
Any help is appreciated. Thanks!
Harlow Pinson
hpinson@indepthl.com
Old Feb 24, 2004 | 06:04 PM
Ducky's Avatar
Get a 90 degree elbow... it will change the direction of the coax to the side... should be avail at any CB shop.
Like this..
http://www.alfenterprises.com/images...ccess/ar-7.jpg
Old Feb 24, 2004 | 07:42 PM
bobzemuda's Avatar
Like this..
Wasn't that what he was saying he got with the "right angle" adapter.
Old Feb 24, 2004 | 07:45 PM
hpinson's Avatar
Yes, I have the elbow adaptor, and there still is not enough room by about 1/4"-1/2".
- Harlow
Old Feb 24, 2004 | 07:50 PM
bobzemuda's Avatar
Harlow Pinson
As for the stock mounting brackets, I plan to drill a hole in the side of my CB which I hope to install this weekend.
Has anyone gott the 18 to mount flush in a 2nd gen?
Old Feb 24, 2004 | 09:21 PM
jacksonpt's Avatar
Senior Member
No. I've got mine mounted there.
You're right... it doesn't fit. I'm not sure what that white plastic is in the back... perhaps a heat duct to the center dash/windshield vents??? Anyways, take a heat gun and warm it up just enough so the plastic softens up some. Then make a small indentation where the 90degree coax fitting would be.
Personally, if that 1/4" isn't good enough for you and you want this thing to be perfect, you need a new CB, or you need to move the one you've got.
Old Feb 24, 2004 | 09:43 PM
Scottiac's Avatar
embarassing though it may be, I went with the duct tape as well.
Old Feb 24, 2004 | 11:34 PM
sick4runner's Avatar
Ode to duct tape
Lets Hear Another One For Duct Tape!
I did the same thing in my brothers acura, i installed his stereo for him and there were no brackets to mount anything so i added some balsa wood and duct tape! the stuff is the greatest! everything is fine with no rattles but i sure hope the balsa wood doesnt catch fire!!! :pat:
"Ode to Duct Tape"
Duct tape is a great, great thing.
To everything gay it will bring
It has good sticking power
I used it to repair my shower.
It can be used for many things,
ever repairing an airplane?s wings.
Duct tape is the one,
That makes other tapes needed none.
Duct tape is the tape with which to go,
Oh Duct tape I love you so.
Poem by Dan Agius
http://www.emba.uvm.edu/summer/2003/03poems.html; 2-25-04.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
voiddweller
Oct 2, 2015 07:47 AM
Brodetski
Sep 30, 2015 11:50 PM
