mobile 1 synthetic
Old Mar 8, 2007 | 07:47 AM
mkgarrison5's Avatar
mobile 1 synthetic
i use mobile 1 synthetic but why does a lot of poeple use it?? any links or pics to see why the difference?
Old Mar 8, 2007 | 09:01 AM
damn, most of you use mobile 1 syn but dont know why??
Old Mar 8, 2007 | 09:41 AM
Nic's Avatar
Nic
I don't use it, but I think most here do because it is more readily available than some other synthetics. You can find it in almost any parts store or Wal-Mart I do believe. Products like Amsoil and Redline must usually be ordered and a lot of people don't like the hassle of having to do that.
Old Mar 8, 2007 | 09:49 AM
hillbilly's Avatar
What Nic said. I've been running Mob1 for years now. Matter of fact, I run Mob1 in everything now (tractor [engine & hydro tranny], snowblower, & generator). Some of these don't get run that often, so I only swap the oil out every other year.
Old Mar 8, 2007 | 03:41 PM
breknraj's Avatar
I've been running Mobil 1 in my vehicles for years. Part of the reason is that we used almost exclusively sythetic oils and greases on the heavy equipment in my old job. I could seed the results of our oil sampling, and the real world results, when we opened up an engine or gearbox. I was always impressed at how good things looked (most of the time we were replacing worn seals, not mechanical components).
I got my own look-see on my BMW a few years ago, when I had to replace a leaking oil pan gasket at 155K. I got the pan off, and other than a little varnishing off to the sides (no idea what the P.O. used), the mechanicals looked like they were brand new.
Mobil also did a test of their own a few years ago, that included lab running and real world running of a BMW 3 series. They put over 1,000,000 miles on it, with regular servicing at 7,500m intervals. When they passed the 1M mark, they tore down the engine, and every single part still measured well within factory specs. They put it back together, and, as far as I know, are still running it.
Old Mar 8, 2007 | 06:01 PM
Elton's Avatar
i use the clean 5,000 as i dont wanna spend $20+ on synthetic
Old Mar 8, 2007 | 07:16 PM
youngbuck's Avatar
Mobile 1 Synthetic is a fine oil. However, unless you are running extended oil change intervals it may be hard to justify the cost of it. I am running it right now in my Taco because I got it extremely cheap. My last oil change was at 7500 miles, and I'm sending it in for a UOA. I'm confident it'll report as just fine.
Old Mar 8, 2007 | 07:38 PM
YM13's Avatar
same here thats what they told me they used in the factory so thats what i filled up with....it cost me about $24 dollars to change the oil with the 5000 whereas it would have cost me nearly $60 with the synthetic.....
Old Mar 8, 2007 | 07:53 PM
UNR.Grad's Avatar
How is it costing that much for Synthetic, Wal-Mart sells 5 quart jugs of Mobil-1 for about $24 and a Napa gold filter is about $6.50, I've never spent $60 on an oil change.
Old Mar 8, 2007 | 08:26 PM
rearviewmirror's Avatar
www.bobistheoilguy.com ..
Old Mar 9, 2007 | 12:32 AM
Jdizzydub's Avatar
I agree with UNR.grad, $60 bucks is steep for an oil change especially if you're doing it yourself...Wal Mart does have 5qt jugs for like $20 bucks. I read up on Mobil 1's test too and besides longer change intervals it's one of the main reasons I use only fully synthetic and my Runner is still going with 175k.
Old Mar 9, 2007 | 03:22 AM
yeah walmart has the cheapest 5qt mobile syn. you buy that, one more quart and an oil filter. its usually 30-35$ for an oil change if you do it yourself.
Old Mar 9, 2007 | 03:23 AM
QUESTION... i use mobile 1 syn and change the oil every 5k miles. majority of my miles come from the highway.. when it comes out its very black. would it be ok if i went 7500 miles between oilchanges?? bc there is the dirty oil factor. yeah i know the oil holds up but still.. anyone?
Old Mar 9, 2007 | 04:38 AM
gpcollen1's Avatar
If the oil is dirty - change it. Mine goes 5 - 7 k and comes out relatively clean. I would not feel guilty if it went 10k.
As for the original questions - i used to use Castrol Syntec adn loved it. Back then it was cheaper then Mob 1. Now it is not so I use Mob 1 b/c itis available everywhere.
Old Mar 9, 2007 | 05:25 AM
how does yours come out clean. no car i have ever had , had clean oil past 3-4k miles. its always jet black..... i do drive about 40-70 miles a day too maybe that has something to do with it
Old Mar 9, 2007 | 05:37 AM
hillbilly's Avatar
I've been using Mob1 for years. I usually go 7500-8K between changes, which means I only change my oil twice a year per vehicle. This is a good things since life is to busy with 2 small kids and maintaining two Toyotas. I do run an oversized Wix 51516 oil filter....
Old Mar 9, 2007 | 05:54 AM
so the "dirt" that accumulates in 7k miles is ok? i know the oil holds up but isnt it bad for the motor to have dirty oil cycling through it?
Old Mar 9, 2007 | 06:03 AM
gpcollen1's Avatar
My oil doesnt come out pristine - but relatively clean. Especially as compared to what you described and what I have experienced with other vehicles.
Old Mar 9, 2007 | 06:04 AM
well i dont know why mine is jet black at 3k miles lol...
Old Mar 9, 2007 | 08:44 AM
breknraj's Avatar
You must have somthing else going on, because the oil I replace at 7,500 miles on both my truck and my BMW is only mildly discolored from use (and certainly not black!)
