Misfire code for cyl #3 ...............
Old Mar 7, 2013 | 07:30 PM
ddwyer's Avatar
The truck threw a blinking CEL two days ago. OBD2 reads a cyl #3 misfire code. It runs like it's missing a cylinder; no surprise, I guess.
I plan to check/replace plugs and maybe the coil pack in cyl #3.
Any other recommendations?
2003 4x4 xtra cab 2.7L
Old Mar 8, 2013 | 12:27 PM
ddwyer's Avatar
I changed the plugs (Toyota OEM NGK). I now throw C0300 (random), C0303 (cyl #3) and C0304 (cyl #4) misfire codes.
I have photos of the old plugs - really bad looking. #3 looks a little whitish, am I correct or imagining a possible head-gasket leak?
Old Mar 8, 2013 | 03:46 PM
J2F42C's Avatar
Time to perform a compression test. Ever overheated before?
Old Mar 8, 2013 | 04:59 PM
ddwyer's Avatar
No overheating. I have yet to perform a compression test on a deeply mounted spark plug hole. My guess is I'll need to get an adapter of some sort.
Old Mar 9, 2013 | 08:04 AM
ddwyer's Avatar
problem solved
I swapped coil packs among the cylinders. The problem followed the coil pack originally in cylinder #3. replaced that coil pack, runs like a top.
Old Mar 9, 2013 | 09:45 AM
Renaud33's Avatar
That is what happened to mine. It was cylinder #3 also. Swapped coil packs and found the problem in the other cylinder so I repaced the coil pack and problem solved.
moparbay
Mar 10, 2023 03:50 PM
Bourbonblues
Dec 15, 2017 05:43 PM
calderp
Nov 16, 2015 02:49 AM
larrys93pickup
Sep 17, 2015 07:05 PM
langry345
Sep 14, 2015 03:36 PM
