Manual Hubs
Old May 18, 2004 | 01:39 PM
az4x4runner's Avatar
Manual Hubs
I've got a set of Aisin Manual Hubs on the way, finally. Is there any special type of grease I should use on them when rebuilding? I read the tech write-up and it didn't specify. Oh..also, is there a Toyota part number for the cone washers, I'm not sure if these come with them or not.
Thanks,
Bryan
Old May 18, 2004 | 02:11 PM
toy283's Avatar
p/n is 42323-60010. The ones for your ADD flanges should be the same thing. If not, I'd start checking all the local dealers. I've never found a full dozen at any dealer around here without ordering them.
Old May 18, 2004 | 02:37 PM
Robinhood150's Avatar
The cone washers from your ADD flange are the same.
Old May 18, 2004 | 11:17 PM
Ok, cool. I forgot about the fact that my ADD hubs have them too.
So I'm guessing it doesn't matter what sort of grease I use on them? That's probably a dumb question, but I have no idea.
Old May 19, 2004 | 07:14 AM
surfrig's Avatar
I'm interested about the grease too. I've also got a set ready to go on.
Silver, I'd like to cruise a trail or two around Prescott. You interested in playing tour guide? I'm there every few months and I'd like to see some of the sights.
J.D.
Old May 19, 2004 | 08:46 AM
Highland Runner's Avatar
Cone washers were $7 EACH at the dealer close to me. Ouch!
Old May 19, 2004 | 01:52 PM
toy283's Avatar
I just use basic wheel bearing grease for the hubs. The trick is not to use too much, just a light coating of all the moving parts is quite sufficient.
Old May 19, 2004 | 02:50 PM
Flamedx4's Avatar
If the bearings are torqued properly the hubs do not get hot. So, basic multipurpose grease from the grease gun is fine. Bearing grease tends to get stiff when cold. Another tip - use marine grade multi purpose grease anywhere where getting wet is an issue (like where isn't that an issue?) It resists water and absorbing moisture. Good insurance for cheap.
Old May 19, 2004 | 03:29 PM
surfrig's Avatar
Another tip - use marine grade multi purpose grease anywhere where getting wet is an issue (like where isn't that an issue?) It resists water and absorbing moisture. Good insurance for cheap.[/QUOTE]
Good call. Thanks for the tips.
J.D.
Old May 19, 2004 | 10:26 PM
KevyWevy's Avatar
i ended up buying and using multi-purpose marine grease that is often used for boat trailer wheel bearings.
Old May 20, 2004 | 12:14 AM
baileymoto's Avatar
what is the advantage to manual hubs?
Old May 20, 2004 | 07:10 AM
tombothetominator's Avatar
now im no master tech, but this is how i understand it. if you dont have manual hubs, your front driveshaft and cv joints are turning all of the time, even in 2wd. This can cause excessive wear and tear on parts that you arent using. Manual hubs makes it so that unless the hubs are set to lock, none of the front driveline is working, and therefore you are saving parts. PLUS it looks way cooler when you have to get out and switch your hubs to lock in a blizzard!
Old May 20, 2004 | 02:44 PM
KevyWevy's Avatar
yup!! ^
Old May 20, 2004 | 05:05 PM
kyle_22r's Avatar
also, not having manual hubs puts more drag on your drivetrain since there's still more than just the wheels spinning. manual hubs will get you somewhat better gas milage
Old May 20, 2004 | 05:49 PM
Ducky's Avatar
False... if it does its not enough to notice... IMHO.
Old May 20, 2004 | 05:50 PM
KevyWevy's Avatar
i really didn't notice any that much either and no gas milage change. but it sure as hell gives you a better turning radius.
Old May 22, 2004 | 11:11 AM
Thanks for the tips guys, I'll probably get some marine grade grease just to be safe.
Old May 22, 2004 | 08:46 PM
kyle_22r's Avatar
well, maybe not better milage, but when you have a wheezy old engine like mine you definitely notice a lot of drag. i could barely hit 55 miles per hour with my hubs locked on the freeway, while unlocked i could do 65+
Old May 22, 2004 | 10:25 PM
Not of you have an open front diff. The turning radius is dictated by the steering stops. You can't turn sharper than the stops.
Old May 23, 2004 | 12:11 AM
KevyWevy's Avatar
hmmmm i guess thats right, but it sure is a lot loser i guess is what im trying to say. hmm now im all confused.
carlspeed
Aug 23, 2015 02:59 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
ItsJustD
Jul 7, 2015 07:49 AM
