Manual hub question
Do the front axles rotate at all in 2wd with manual hubs in the "free" position? I've got a split in one of my CV joints that I haven't had time to replace. Am I doing any damage to the joint, assuming it's not already shot?
I'm wondering if there's enough friction with the wheel turning to make the axle turn.
Pound out the studs on your axle side when you pull the CV. Makes a ton of difference getting them in and out. I only have to jack under the bottom A-arm about 1/2" inch to do mine - no disassembling the upper arm or ball joints.
I replaced my studs with the same size bolts. Total investment was $12 for both sides.
No the axles shouldn't move with the hubs in the FREE position. To check to see if they are, you can pull the transfer case lever >slowly< toward 4HI while moving. If the gears start to gnash, don't continue into 4HI. That means the front driveline is not engaged.
rushw
Jul 18, 2015 01:46 PM
