Maintenance Questions for a 99 4runner
Old Mar 13, 2008 | 09:10 AM
YotaNewbie's Avatar
I had a CEL on for months and I finally had it diagnosed: P0170 (I think), the MAF sensor.
Herb Chambers Toyota of Boston charged me $345 to replace it and told me that it "couldn't be cleaned".
Was I taken for a ride?
1999 SR5 Highlander
Old Mar 13, 2008 | 09:25 AM
Greedy's Avatar
1999 SR5 Highlander
If it was your MAF - it can be cleaned. If it was your 02, it cannot. Either way, $345 is a crap load for either. Too late to worry though, they won't get you next time!!
Old Mar 14, 2008 | 05:19 AM
edzo's Avatar
also wanted to say....if you have a rear heater
check the lines feeding it. they do corrode (especially
if the thing has been jammed into repeated snowbanks) and can leak
Old Mar 14, 2008 | 06:31 AM
DeathCougar's Avatar
1999 SR5 Highlander
Yea, major ripped off there. Considering you can get the part for $110, and its two screws, a plug, and about 2 minutes to replace it.
Old Mar 14, 2008 | 10:29 AM
  #25
YotaNewbie's Avatar
They sort of screwed me on a bunch of stuff, I think. I'm going to put a post together where I go through each item I had taken care of line by line. If it turns out they took advantage, I'll go talk back there and have them explain the charges to me.
Old Mar 14, 2008 | 09:21 PM
  #26
98runner210's Avatar
It's all buyer beware dude. Dount they are going to do anything after the fact. Again keep in mind that going to delaerships for service is usually the MOST expensive option. Although you can usually count on the dealership for quality work.
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87turboPA
Jul 12, 2015 07:49 AM
Cplmike
Jul 8, 2015 08:47 PM
colinmil
Jul 6, 2015 04:03 PM
