LSD Questions
Old Mar 30, 2010 | 01:31 AM
NwRunner's Avatar
LSD Questions
I was checking the local craigslist when i found this http://www.tlsperformance.com/trdlsdkalisl.html
It says it will fit 96-06 V6 models of the tacoma, but doesnt say it fits the 4Cyl?
Do the V6 and 4Cyl have different axels?
Old Mar 30, 2010 | 01:41 AM
KZN185W's Avatar
the 4 cyl has only 2 pinions, i think. but the number of splines are both 30
Old Mar 30, 2010 | 01:48 AM
Matt16's Avatar
Different diffs and gearsets, not compatible. You could however, buy a V6 diff (cheap, assuming you have common stock gear ratios) and install the LSD into that diff which will bolt in to your diff housing without modification.
I don't think I'd go to all that trouble for a LSD though, they're not that useful for off road usage, more for street/track usage.
Old Mar 30, 2010 | 08:15 AM
EnolaGaia's Avatar
It WILL fit (assuming you don't have the TRD e-locker).
All 6-lug 1995.5 - 2004 Tacomas (except for those with the TRD e-locker) use the larger heavier differential commonly (and mistakenly) referred to as the '8.4'. This is the same '8.4' used in early Tundras and T100's (as well as 5-lug 2WD V6 Tacomas).
However ... As already mentioned, an LSD may be a questionable add-on for off-roading purposes.
jaretstuff
Aug 4, 2015 02:08 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
coffey50
Jul 28, 2015 10:55 AM
