lower my RPMs at 80kph
Old Sep 30, 2003 | 03:50 PM
crazyhick's Avatar
Just picked up an 1980 4wd Toyota .... i've got the 4 speed manual and i do alot of highway driving .... my rpms are way up at 3 grand when i'm runnin' 80 kph.
I dunno what that is in mph 50 ? sucks ..... i figure toss on some taller tires might do it .... but does anyone make a bolt on overdrive for this rig ? ..... any more ideas?
Old Sep 30, 2003 | 03:52 PM
Victor's Avatar
Easiest fix is the tires like you mentioned. That 4 speed is notoriously weak but the 5 speed that replaced it is very good. I'd try to find a 5 speed before I considered putting in higher diff gears.
Old Sep 30, 2003 | 04:31 PM
crazyhick's Avatar
to tell you the truth i heard the exact opposite about the 5 speed. Don't know if he's really a reliable source though.
but i do know the 5 speed is 4 inches longer ? ... is there an adapter for that ? .... or do i cut and paste?
Old Sep 30, 2003 | 05:50 PM
Glenn's Avatar
The early 5 speeds are to be avoided.
You would basically have to do some driveshaft alterations to make that work.
Old Sep 30, 2003 | 06:11 PM
Victor's Avatar
Damn your right. G series 5 speeds suck and W series are much better but those are for later trucks. You have an L series tranny which I have almost no info about. What axle ratio and tire size do you have?
I found this page but it doesn't list much info about tranny strength: http://www.4x4wire.com/toyota/faq/
Marlin's truck may be the best example of a first gen around so I'd ask him what is possible.
Old Sep 30, 2003 | 06:43 PM
kyle_22r's Avatar
i believe you have that reversed. the 4 speed was a clunky bulletproof tranny, but the L and G series 5 speeds are pieces of junk that tend to blow up when you need them most
i'm thinking about putting in a w56 out of a 85+ truck and having my rear driveshaft shortened and front lengthened
Old Sep 30, 2003 | 07:02 PM
crazyhick's Avatar
thanks
If the truck is still runnin stock gear ratios ... i should have 4:37s in my axles .... i'm pretty sure i'm running a 255/75R at the moment (i'd have to double check) ....
I am looking at buying a used set of 30 inch mickey tompsons ...
how much of a change in tire size would i have to go to lower my 4th gear RPMs 500 to 1000 rpms less?
Old Sep 30, 2003 | 07:06 PM
kyle_22r's Avatar
probably quite big...and as gutless as these trucks are you'd probably best spend that money on a 5 speed tranny
right now on my 31.5" tires, i push about 3000 at 65mph
Old Sep 30, 2003 | 07:15 PM
Victor's Avatar
Sounds like 31's would be about right. 4.56 and 31's is right for the newer trucks.
Old Sep 30, 2003 | 07:47 PM
kyle_22r's Avatar
only problem is that the newer trucks have 5 speeds in them, while we're stuck with our 4 speeds from the days of 55mph speed limits...
Old Oct 1, 2003 | 04:47 AM
Victor's Avatar
So 4th gear in your 4 speed has no overdrive? I'd say you could do 33's if that's the case although that would probably make your truck slow as a slug.
I think a 265/75r15 is a 31 so you should consider at least 32 but then we have to start looking at clearance and lifting.
Old Oct 1, 2003 | 05:32 AM
Glenn's Avatar
...I think a 265/75r15 is a 31 so you should consider at least 32 but then we have to start looking at clearance and lifting.
Yes, it's the metric equivalent of 31x10.50x15R.
Old Oct 1, 2003 | 07:18 PM
crazyhick's Avatar
always looking for another reason to lift
Old Oct 5, 2003 | 05:24 PM
crazyhick's Avatar
I've scooped a set of 31" 10.50 Rs off an old truck of ours, to test em out for fit .... should be a good time
Sleaker
Aug 26, 2020 06:03 AM
O Holy P
Aug 18, 2015 02:33 PM
JefferDean
Jul 31, 2015 10:39 AM
ty1er
Jul 19, 2015 06:42 PM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
