Low idle...
Old Dec 21, 2002 | 07:21 PM
rpeAMP's Avatar
Low idle...
Hey all,
My 92 has developed a seemingly low idle here recently. It used to idle at around 500 RPMs (700-750 w/ AC compressor load), however now without the A/C compressor on, it idles at 250 RPMs (the first tick mark). The only vibration I noticed at first was in the gear shift (5 spd.), however now it sometimes shakes the entire truck. When A/C compressor kicks on, it goes right back to the 700s. I know there's a screw on the top of the engine I can turn, but is this just a temp. fix or is there something else going on here?
Thanks for any input.
Old Dec 21, 2002 | 07:25 PM
JustAnotherJodieFE's Avatar
Your first thought should be to look at your throttle body, it's probably very nasty.
Which motor do you have?
Old Dec 21, 2002 | 07:33 PM
rpeAMP's Avatar
It's the 3.0 V6. Should I go ahead and turn the screw to tweak the idle or should I just deal with it until I can clean the throttle body? BTW- Where is it located and how would I clean it if I had to?
Old Dec 21, 2002 | 09:09 PM
metal22lica's Avatar
Click ME for a TB cleaning page.
Old Dec 21, 2002 | 09:50 PM
rpeAMP's Avatar
Thanks! I will definately give that a try and see what happens.
Old Dec 21, 2002 | 10:00 PM
jx94148's Avatar
This can also be caused by dirty or improperly gapped spark plugs. Dirty air filter, warn out distributer cap or rotor, etc.
Old Dec 22, 2002 | 06:57 AM
rpeAMP's Avatar
Maybe this will help narrow it down some...the truck is now dying anytime I put in the clutch (or allow it to sit idle anytime when it's warm. BTW- Temp. gauge shows normal.
Old Dec 22, 2002 | 08:16 AM
supascout's Avatar
Is your check engine light on? If so check the codes, if not there are several areas to look into! If you notice signs of mixture problems (rich/lean) then perhaps the MAF (mass air flow sensor)... Easy to test with an ohm meter and a little breath. There is a possibility that you have a vacuum leak and you are not actuating your throttle plate vacuum motor (which keeps the car idling at its predetermined speed. Also there will be a throttle plate position sensor that may be a contributing factor! Once again check the trouble codes, if the problem is electrical then the car will tell you what is wrong. I had a similar problem on a 91 Land Cruiser and was able to fix it by cleaning the IAC (idle air control valve)!!! Let us know what the check engine light reads. To throw one more on the pile a pluged fuel filter can kill an engine, although normally at speed, not at idle!
travis
Old Dec 22, 2002 | 10:03 AM
rpeAMP's Avatar
Hmmm...no check engine light, although I wish it was on, as it would help alot as to the problem. The truck dies now any time it is in neutral, even when I first start it up. This has just recently started happening (as of yesterday), and I filled up just the other day as well. I'm beginning to think I have a bad tank of gas. Would that cause this problem? BTW- Truck works wonderfully in gear and on the highway, only when I pull it out of gear does it stop (and the engine will die if you pull it out of gear while on the highway).
On a side note, the only thing that will keep the engine going when in neutral is either giving it a little throttle or when the A/C compressor kicks on. I've tried turning the screw a little bit (don't know how sensitive it is), but no avail.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
coryc85
Dec 5, 2015 08:42 AM
bhaithc
Sep 17, 2015 07:53 PM
chuckd83
Sep 14, 2015 03:20 PM
Boomer8404
Sep 10, 2015 09:01 AM
