Low fuel light?
Old Oct 14, 2009 | 06:43 PM
wunbigtacoma's Avatar
Low fuel light?
You know i just noticed the other day that my low fuel light doesnt work....in fact i dont think that its been low enough but i let it get in the red and it doesnt come on...95' Taco 3.4 any sugg,be great thanks
Old Oct 14, 2009 | 07:00 PM
kszach's Avatar
I'm beginning to wonder if my light works also. My last fillup, the gauge was on E for awhile but I filled up with less than 15 gallons. I believe (?) that we have a 21 gallon tank so I think maybe this gauge is just biased. I am on E again, this time I am going to push it (maybe I should fillup a 5 gallon gas can on the way to work tomorrow just in case).
I have a 96 ext cab, 3.4L auto, 4wd, btw.
Old Oct 14, 2009 | 07:13 PM
Wounder if it would have to do with the package..like sr5,lx is what mine is,but heck you think it would work right? lol
Old Oct 14, 2009 | 07:14 PM
SnowRunner98's Avatar
mine unfortantly comes on, reminds me that I'm broke and time to fill up. lol is it a bulb or a sensor? I noticed when mines on, its like on fumes.
Old Oct 14, 2009 | 07:17 PM
Not the bulb on mine done checked it,do you know if it has a separate sensor some where
Old Oct 14, 2009 | 07:35 PM
rimpainter.com's Avatar
The fuel sending unit is a known issue on the 5VZFE powertrain/fuel monitoring system (mainly earlier versions). When I removed the stock fuel pump for the Walbro 190 pump, I looked for obvious signs of an issue and I noticed that the float arm moved a metal tab past a series of contacts. Some of the contacts were black. I could not get the black off, but I did make them a little better by using an eraser. The contacts that were black were in the same range I was (and still am) having issues with. My issue, by the way, is that the fuel gauge goes down extremely fast between F and 1/2 a tank, then slows down significantly. The low fuel light comes on when I have 4+ gallons left. Seems like you may have the opposite problem.
Old Oct 14, 2009 | 07:59 PM
anybody know a fix for these? can u test it????
Old Oct 14, 2009 | 08:08 PM
You can test it, but you have to drop the fuel tank to do so. If you're going to go through all that trouble, you might as well replace it (the FSU). I think you can measure the resistance of the contacts if memory serves me right. There might be a TSB out for this issue.
Old Oct 14, 2009 | 08:44 PM
98runner210's Avatar
I thought the low fuel light was activated by that switch cylinder looking thins that sits on the arm with the wire coiled down to it.
Old Oct 14, 2009 | 09:01 PM
You might be right about that. I guess I got a little sidetracked on the FSU fuel/gauge issue...but that's a good point. If you drop the tank you might be able to check the low fuel light part as well (I have no experience with that) as mentioned.
Old Oct 15, 2009 | 03:32 PM
yea thanks i just figured might be something a little easier then droppin the tank,its my dd
Old Oct 15, 2009 | 05:48 PM
cosmophonic12's Avatar
mine dose the same thing. 2000 4runner
Old Oct 27, 2009 | 03:13 PM
is their a way to adjusted/calibrated it,or something mine does have white face guages,bet thats why it does work...just maybe
Old Oct 27, 2009 | 03:23 PM
vital22re's Avatar
totally a bro
is the float on the fsu dammaged?
Old Oct 27, 2009 | 03:48 PM
dont know but wouldnt think so...
Old Oct 27, 2009 | 10:42 PM
ESQ's Avatar
ESQ
I think it is the little cylinder thing with the copper wire coiling down to it. Can't think of any other function that thing might have.
Old Oct 28, 2009 | 07:30 AM
kawicowboy's Avatar
I have a 96 Taco and Im fairly certain that it does not have a fuel light at all, I will have to look into this.
Old Oct 28, 2009 | 10:40 AM
That's correct. When the fuel level gets too low and looses contact with that cylinder that's what causes the light to go on.
Old Oct 28, 2009 | 04:46 PM
chad1041's Avatar
95.5 taco here lol these trucks have a fuel light??
Old Oct 28, 2009 | 05:33 PM
Shawn6string's Avatar
you all need new fuel sending units...they wear out and get coroded thus not reading right or at all. Some even give you a false reading on how much gas you have.
