low fuel light
Old Feb 22, 2007 | 09:13 AM
  #41
ScubaDuck's Avatar
What reset procedure?
Check out post #15 in this thread:
https://www.yotatech.com/forums/f2/3rd-gen-fuel-gauge-problem-i-think-i-figured-out-problem-pics-60260/
-Scubaduck
Old Feb 22, 2007 | 09:17 AM
  #42
mkgarrison5's Avatar
https://www.yotatech.com/forums/showthread.php?t=60260
-Scubaduck
where does it talk about reseting and how to?
Old Feb 22, 2007 | 09:32 AM
  #43
ScubaDuck's Avatar
In post #15 of the thread, Ringmaster sets out the reset procedures from the TSB (which applies to the 99 and 00 4Runners). I see you have a Tacoma, so I have no clue whether this will work for you. Anyway, this is what Ringmaster posted in the other thread:
Electrical EL010-99 99 & 00 4Runner
Vehicle has to be sitting on a level surface with an inclination of +/- 0.5 degrees.
1.With the ignition switch in the Off position, press and hold the trip speedometer reset button.
2. Continue pressing the reset button while turning the ignition switch to the On position.
3. Within 5 seconds of turning the ignition switch On, release the trip switch, press trip switch 3 times and on the 3rd press, hold the switch for 5 seconds. The buzzer will sound for 1 second at 800HZ.
4. After the buzzer stops, release the trip switch.
5.Press the trip switch one more time and hold for 5 seconds. Once more the buzzer will sound for 1 second at 800HZ.
-Scubaduck
Old Feb 22, 2007 | 11:33 AM
  #44
surf4runner's Avatar
Originally Posted by 2000t4r
(I say 20 because I average approx 20 gallons per mile)
thats gotta be the worst mileage ever
Old Feb 22, 2007 | 12:03 PM
  #45
rdlsz24's Avatar
Luckily my low fuel light works since my fuel gauge doesn't. I usually don't try and go farther than about 20 miles once the light says on constant.
Rob
Old Feb 22, 2007 | 12:11 PM
  #46
outrages112's Avatar
whats the reset procedure do?
Old Feb 22, 2007 | 01:29 PM
  #47
Javin028's Avatar
Originally Posted by Gerdo
Not sure what everyone is driving but the 2000 4runner has an 18.3 gal tank, or so the manual says. I once drove 85 miles after my light came on and still had 2 gal left. I was carring a fuel can, with gas. FYI, the fuel pump is in the tank. The fuel cools the pump. If you run your tank low alot you are allowing your pump to get hot which could shorten its life.
I also drive a 2000 4Runner but mine is a 2.7. Before my last fill up, I drove about 40 miles after the light came. The needle was below the bottom line, and I still had over 4 gallons left. I still get nervous everytime the needle gets that low...haha.
Old Feb 22, 2007 | 03:07 PM
  #48
69goatfarmer's Avatar
-Scubaduck
Oh well, it doesn't apply to my 4Runner. I have a '96 and that tech note is for '99 and '00 trucks. Thanks anyway Scubaduck!
Old Feb 22, 2007 | 08:19 PM
  #49
2000t4r's Avatar
Old May 2, 2007 | 11:18 AM
  #50
Motayota's Avatar
Man, mine is really sensitive, fuel gage looks like it drops in a linear fashion, but the light comes on early and I fueled up after the light came on and stayed on for like 10 miles, it only took 13.2 gallons, that means I have like 5 gallons left when the light comes on, a good 80-100 miles.
I'm going to try that recalibration thing and see if it does anything for the low gas light.
Luis
Charecter1
Nov 6, 2023 10:08 AM
jbv808
Aug 6, 2021 04:47 PM
Sleaker
Aug 26, 2020 06:03 AM
Sep 4, 2015 09:27 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
