Look what I found on ebay
Old May 5, 2003 | 08:26 PM
Hawaiian4R's Avatar
Aisin hubs for auction, check it out.
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6780
Old May 5, 2003 | 09:55 PM
calrockx's Avatar
i need to ask this: what are (aisin) hubs, and what do they do?
Old May 5, 2003 | 11:04 PM
Hawaiian4R's Avatar
Do a search on them, there's only good things about them.
Old May 6, 2003 | 12:19 AM
UKMyers's Avatar
I'll try and help with a quickee answer. Aisan hubs are manual hubs meaning in order to get 4WD you have to physically get out of the truck and turn them "in" for them to lock and then you will get 4wd. If your hubs are locked but your in 2wd on the lever the front axles are always turning, which is also what happens with ADD (automatic disconnecting diff....and what you probably have). The advantage of having the manual hubs is when you turn them "out" the front tires are freewheeling and nothing is turning up there so there is less wear and tear, less rolling resistance ( better mileage) and the truck will steer easier most likely as well. Hopefully the guys who have already converted can chime in with some of the results. It is also discussed in this thread
Rasteirinho
Nov 6, 2017 03:40 AM
shisha1999
Aug 14, 2015 01:33 AM
irritech
Jul 27, 2015 05:15 PM
msane99
Jul 17, 2015 10:13 AM
wilbertd
Jul 6, 2015 07:39 AM
