lock cylinder removal
Old Jan 28, 2013 | 02:38 PM
mickey1's Avatar
Question lock cylinder removal
I am new to YotaTech and this is my first thread: I am installing all new locks (doors, glove box and ignition) on my '97 4Runner (Limited) and am having trouble figuring out how to remove the door handle on driver's side. And, even if I were to figure out how to remove it, I still do not know how to disconnect the lock cylinder from the handle itself. Are there hidden screws or a clip or something? Thanks for your help! One more question concerning ignition lock change. Do you really need to remove the steering wheel in order to change the ignition lock cylinder. Can't you simply remove lowest trim panel and then remove ignition switch trim piece and then, after moving key to ACC position, pull switch out with key? Thanks for the help guys (and gals)!!
Old Jan 29, 2013 | 04:54 PM
rbarthol's Avatar
i had to remove the door lock recently. did not fix it, but got it working.
search yota tech for door lock wont turn or something similar; there are a lot of suggestions.
k ball did a great write up on 4rorg. his llnk was in yotatech thread.
search youtube; a1auto or 1a auto shows how to get into the door.
search google to get deeper in the cylinder.
Old Jan 29, 2013 | 05:48 PM
kball's Avatar
Here you go
http://www.toyota-4runner.org/3rd-ge...tml#post676893
westonian18
May 1, 2020 06:38 AM
Sep 4, 2015 09:27 AM
256mbaker
Jul 31, 2015 06:45 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
AaronM
Jul 8, 2015 07:15 PM
