locating current opening efi relay
I have a 1986 4 runner. The fuel pump is new and works fine. Once installed, I tested it with a jumper wire, direct from the battery. The car starts just fine. However, it won"do so on it's own, there is no power to the pump. I checked with the parts department, at three different dealers, and they all say that the likely cause is a defective current opening efi relay. Now they all say It's located under the dash on the passenger side. I pulled the kick pannel, and the glove box. There is a relay left of the glove box opening, but the numbers don"t match. The part No. on the side of the correct relay is supposed to 8591014020. I need to find the correct relay to replace it. Plus they indicate there's now way to test the relay, Is that true? Any help would be appreciated. Thanks.
Circuit Opening Relay location
You'll probably find most of that information on my web page (and it is the Circuit Opening Relay):
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Hint: Look behind the ECU
circ open relay location
the circ opening relay is up in there on the side wall behind your speaker. U probably checked fuses and Main EFI relay already but i thought i would mention it also. Ive just been all through that on my '85. good luck
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
WTB[PacNorWest]: WTB - Tacoma/4runner 3.4 Charcoal canister and igniter
94whiterunner
07-12-2015 07:15 PM
