To LINE-X it or not LINE-X it
Old Jan 14, 2004 | 04:45 AM
mummer43's Avatar
Originally posted by poomba
We spray Rhino at my shop and after seeing every coating imaginable, I think if you want no-holds-barred tough go Rhino. For looks Armourgard ( Canadian Line-x) but if it just needs to be sealed-Herculiner. But remember, if you go with some brush on coating, don't ever plan on getting it Rhinoed or Line-X because its got to come off first! But all said, all coatings are tough. Just depends how you're going to use it...
Line-X is tougher than Rhino. I got samples of both and rubbed them together and the Rhino sample started to get sanded off. I did it above a white piece of paper and I could see the Rhino shavings falling on the paper. Rhino is fluffier than line-x and not as dense. I jabbed a knife into both and the knife would barely pierce the line-x and it would go right through the rhino and leave a noticeable gash.
Old Jan 14, 2004 | 04:55 AM
rimpainter.com's Avatar
I worked at Rhino for 2 years. It comes off when you rub them together because the Line-x is harder more abrasive than Rhino. You want flexibility in the back of your truck, not hard plastic. Temperature fluctuations will cause cracking to a hard material over time.
I have personally stripped 3 Line-x's out of trucks at a cost of $175 to put Rhino in. That was 6 years ago, things may have changed since then. Rhino is the originator - stick with the best.
My .02.
Old Jan 14, 2004 | 05:17 AM
mummer43's Avatar
You may have a point, but I believe they both come with a lifetime warranty, so if anything happens you take it back to whoever sprayed it and have it fixed for free.
That's true. And like I said, over 6 years a lot can change.
Old Jan 14, 2004 | 05:37 AM
  #25
mt_goat's Avatar
Originally posted by cruizin01
that looks sweet on that bumper, I might take my safari bar off before I put my piaa's on it and spray it with that stuff..Ive got some left over. Cool
I guess I should say that I top coated the Dupli-color truck bed spray with SEM Chip Guard in satin black to get a slight shine to it. The bed spray by itself is flat black.
Old Jan 14, 2004 | 06:36 AM
  #26
cruizin01's Avatar
The shine of that Dupli-color depends on how you spray it. If you dont spray it on heavy enough it will be rough and flat looking. Thats an easy way to tell you whether you got enough on it or not. On my bed rails and gate I made sure I sprayed it on plenty "wet" and it looks smooth and shiny. I ran out and took a pic this morning for anyone thats interested.
Old Jan 14, 2004 | 07:36 AM
  #27
mt_goat's Avatar
Oh ok, yes I was trying to keep the texture very fine and I didn't put it on very heavy. That's why it was flat for me.
Old Jan 14, 2004 | 09:21 PM
  #28
poomba's Avatar
If the Rhino isn't mixed right before it's sprayed it will do alot of funny things. That sample you played with must not have been done right. We've got a bunch of samples ie. hammers, teenage mutant ninja turtle, etc that we let the customer go to town with an exacto knife and after 6yrs, the turtle is still doing fine.
Old Mar 23, 2004 | 07:06 PM
  #29
Darx's Avatar
Originally Posted by Darx
I've been debating over or under the rail Line-X myself.
If you go over the rail can you still put a shell on the bed? I don't see why you wouldn't be able to and you'd be protecting the contact surfaces. The only thing I can think of is the seal the shell wants to make with the bed wont be there.
I went ahead today and had the truck bed Line-X'd, over the rail. After this past weekend offroading I really got tired of hearing the bedliner rattle around all day. The rails were in okay shape but some rubbing is evident. On the tailgate it was down to the metal in spots.
There are some spots that the rails rubbed on that are pretty low down on the bed rails so I'll have to have it buffed out I imagine.
Great investment and looks awesome, had them put on the UV protectant spray too. I only wish I had had the cash at the time I purchased the truck to have it done. Drop-in bedliners are the devil!
Old Mar 24, 2004 | 03:35 AM
  #30
4RunnerFever's Avatar
Good call - I had Rhino lined our 2002 Tacoma and it took FOREVER! I'll go line-X for sure next time around.
Old Mar 24, 2004 | 04:15 AM
  #31
SLC Punk's Avatar
I had Rhino Lining in my old 94 Ranger. It was 100 times better than the bedliner that I had. I think mine was just under $400 for over the rail.
Old Mar 24, 2004 | 08:28 AM
  #32
Darx's Avatar
Pics
Here's some pics for the heck of it:
Old Mar 24, 2004 | 10:28 AM
  #33
Krash's Avatar
For me I went line-x because I liked the look of the material better, not to mention my dad has had line-x on his truck for the past 6 years. I think the only chip in his line-x is from us putting the cherry picker in, other than that the stuff is still going strong.
Old Mar 24, 2004 | 11:42 AM
  #34
4cedRunner's Avatar
Originally Posted by amusement
Grab a brush and use Herculiner. It's less expensive. It's as good as Line-x.
Here's Ebay's Herculiner auctions
<click me>
Here's Herculiner's web page www.herculiner.com
It might be less expensive and a cost effective alternative but to say it is just as good is hardly true. Line-X is the nicest liquid bedliner available. It is just a question of can you justify the additional cost. It bonds better and lays on smoother, as well as plenty of other benefits to any DIY bedliner.
Old Mar 24, 2004 | 11:44 AM
  #35
4cedRunner's Avatar
Good choice on the Line-X it looks so nice! You will be pleased with he long term results.
39 Thieves
Jan 6, 2017 01:08 PM
Badfish740
Feb 24, 2012 05:13 AM
GregStevens
39
Nov 25, 2008 06:14 PM
SwampThing
10
Nov 25, 2006 12:38 AM
Salue
34
Feb 28, 2005 07:19 AM
