lights seem to be a little dull
Old Feb 13, 2007 | 07:20 PM
spage's Avatar
Originally Posted by 4Crawler
I would recommend first checking the voltage at the back of the headlights (while they are on) to make sure that is not the source of the dim headlights (it often is). If the voltage is low, light output (and lifetime) will be greatly reduced and even a high buck bulb won't make it much better:
http://www.4crawler.com/4x4/CheapTri...ryBeforeYouBuy
Good to know. I'll try that for sure.
Old Feb 13, 2007 | 07:56 PM
SteveD0603's Avatar
Originally Posted by Mason Dixon
these are probably the brightest on the market right now
http://www.nam.lighting.philips.com/...tremepower.php
That's what I've read, too. They are in such demand that places are taking advance orders for them so they can meet it. I'm either getting a set of those, the European version of the Silverstar, the Osram (no comparison between it and the US versions), or the IPF Magic J. Waiting to see what the budget will allow first.
I'm trippin' on all this talk about Silverstars being so good. If everybody would read some of the good info out there on current lighting technology and good bulbs vs bad bulbs, I think the Silverstar popularity and hype would "burn out" pretty quickly. I know, I own a set, unfortunately!
Old Feb 13, 2007 | 08:25 PM
Fo_SheeZy's Avatar
PIAA super white's are the best.
Old Feb 14, 2007 | 12:34 AM
mpavolka's Avatar
I have the silverstars and they are way brighter than my old ones. Check around though... I swapped the sealed beams in my 90' 4Runner for the hella's which were like the new style. Then I found bulbs for $9 a piece at Baxter's Auto Parts that were 90W low beam with 130W high beam. They were incredible and illegal but they were aimed right and I never had a problem. However I haven't been able to find them again. Make sure you stay away from cheap/flashy bulbs that say equivalent Watts... as they tend to not be any good.
Old Feb 14, 2007 | 06:07 AM
  #25
SteveD0603's Avatar
Very true!
ashersullivan88yota
Jan 18, 2022 05:37 PM
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
