Lifting a Tacoma
Old Feb 3, 2003 | 05:30 PM
Dashunde's Avatar
Lifting a Tacoma
What would be the best way to lift a Tacoma about 1.5" in the front and 1" in the rear?
What would some of the drawbacks be with that small of a lift?
Thanks!
Old Feb 3, 2003 | 05:43 PM
2wheeler97's Avatar
what tacoma are we talking about?
It depends on what tacoma were talking about. There are a few important factors. Obviously, the year is important, as supsension systems change between different years and generations of a vehicle. Also, is it 2wd or 4? If 2wd, is it a 6-lug or 5-lug? Also, what engine do you have, and is the cab regular, extended, or double?
Tell us what truck we are starting with, then we can make some recommendations.
Old Feb 3, 2003 | 05:47 PM
Dashunde's Avatar
... I forgot to check the "show signature" option. :confused:
Old Feb 3, 2003 | 06:45 PM
sizzzletits's Avatar
for that small of a lift get some OME 881 front coil springs can be found numerous places on the net, check www.ultimate-offroad.com and an add a leaf for the rear. im not sure on which one to get as there is all different kinds, i run a 2.5" procomp AAL on my truck. everyone seems to like the full length downey add a leafs.
Old Feb 3, 2003 | 07:41 PM
nags's Avatar
I was wondering the same thing.. I wanna lift mine like 2 inches all the way around.... It's an 03 doublecab.. 2wd with the 3.4l v6
How much am I looking to spend?
Old Feb 3, 2003 | 07:57 PM
WATRD's Avatar
Spacers or new coils for the front, coilovers if you have the $$$.
In the rear, you can with a mild AAL, a shackle or even a block. I would say stay away from the block, even one that small.
An inch or two is enough to set you off from the stockers, but not enough to really go up in tire size. For about the same cost, you could go up 2.5" and be able to run 32's with ease...
Since Tacoma's all have the same suspensions, other than the '95.5's, that is not really a factor.
What are you going to use it for?
Nags -
For a spacer lift you are looking at;
2" full kit Part # Taco-2" kit Uses 2" front lift spacers with Fabtech rear aal, new longer rear shocks, and the BPV bracket. Leaves the truck level. $275 + shipping ($25 east coast/$40 west coast)
But you may be able to get some of the parts like the shocks and AAL's a bit cheaper by shopping around...
Old Feb 3, 2003 | 08:13 PM
nags's Avatar
Nags -
thanks. I'd like to be a little bit different than stock, but I definetley dont want to buy new tires
Old Feb 3, 2003 | 09:26 PM
ALee27's Avatar
just contact Mike (Pleaseturnmeover) at xtremeoff-road..com. he has great service and hes on this forum! i jsut ordered gears and some OME products from him.
Old Feb 4, 2003 | 02:51 AM
Dashunde's Avatar
I'm not really going to "use" it for anything, and I dont plan on any tire size changes.
On my level garage floor, measured from the floor through the center cap up to the bottom of the TRD fender flair...
The stock front end is 35.5" and the rear is 36.75" so the truck sits a bit nose-low. I dont like its current "stance".
Old Feb 4, 2003 | 05:38 PM
rowan's Avatar
dashunde - just want to say, that sounds like a really nice truck!! hope it works well for you, but it will, cause its a toyota.
Old Feb 4, 2003 | 06:22 PM
Corey's Avatar
Co-Founder/Administrator
Dashunde, if you geta hold of Mike at www.xtremeoff-road.com, he goes by XtremeOff-Road on the board here.
Old Feb 4, 2003 | 06:42 PM
ChitRod's Avatar
If i'm not mistaken the stance is that way so that when the back of the truck is loaded then it won't rub on the tires. Kinda wish 4runners worked like that when they were loaded.
Old Feb 4, 2003 | 09:03 PM
2wheeler97's Avatar
I didn't like the sagging front end look on mine either. If you go with add-a-leafs in the rear, it will also prevent your truck from sagging too much in the back with a heavy load. Keep in mind with add-a-leafs, changing shocks is a must to keep shocks from over stretching or bottoming out, but also consider getting stronger shocks. I say this because I got a Fab-tech lift and the add-a-leafs came with "Fab-Tech" shocks. I found out later from a friend that owns an off-road shop that the shocks are really just monroe's with the fab-tech name on them. I have rancho's, and they suit me fine, though most people here will recommend bilstein's, atleast that as been my impression here. Just remember, some comes that make lift kits for trucks, may sell you shocks as well, but they might not be worth getting in a package deal. You might want to consider buying shocks separately from a company that specializes in shocks only.
Old Feb 5, 2003 | 02:10 PM
Dashunde's Avatar
Thanks for the info guys... I'm probably going to put a Cornfed spacer in the front for now. I'll wait until the original tires are slick and then I might go with coil-overs and a 2-3" lift all the way around...
Old Feb 5, 2003 | 09:23 PM
nags's Avatar
damn.. sounds pretty expensive for such a small lift.. I'd also need to have someone install it all for me too
Old Feb 5, 2003 | 09:39 PM
WATRD's Avatar
Yep, it's almost not worth going for a lift smaller than 3" since that extra inch is not that much more. Plus, it's the same amount of work.
If you have never done a spacer lift before, it seems pretty daunting. But after the first one, you will never pay someone to do it again... Rather than have a shop take advantage of you, I would suggest you hook up with one of us who have done a few of them and cut your costs down to the traditonal "beer and pizza"
Gene, AKA "Dread" who you see around these parts has got it down to a science now and I watched him take his front suspension apart, upgrade it and put it all back together, by himself in the driveway of the shop where I was working on my rig All this took him just a couple hours
Old Feb 5, 2003 | 09:44 PM
nags's Avatar
I wouldnt mind going for 3", but defintley no more. It's gonna be too hard to load a bike..... What do you think i'm looking at pricewise for a 3" lift?
Old Feb 5, 2003 | 10:09 PM
WATRD's Avatar
hahhah Well, you will get no sympathy from me there... try loading anything with nine full inches of lift plus bigger tires heheh ...and I am making preparations this weekend to make one more step up But back to the business at hand...
To achieve 3", your options are pretty much the same as when you go 2". From about $750 for coilovers, AAL's and new rear shocks down to a used spacer lift from somebody else, a used AAL and used rear shocks for ~$100 or so.
In the middle, Cornfed shows the following prices;
2.5" size Part # 2S-Taco-2.5" $145 + shipping/handling
3" size Part # 2S-Taco-3" $150 + shipping/handling
You can pick up a 2.5" AAL for $50 or so and rear shocks are about $75 each for good ones or $40 each for cheapo's.
Cornfed also shows a complete kit, but I hear the shocks are nothing to write home about.
3" full kit Part # Taco-3" kit Use Procomp EXP-13120 rear aal, new longer rear shocks, and the BPV bracket. Leaves truck level.
One final thing to remember is that it's not a bad idea to drop your front diff an inch if your are going up to 2.5 or 3" of front lift. The kit for that is about $30 if you even have to buy it. Some places include it with the spacers. Dropping your diff does wonders for CV angles and keeps them much healthier. I recommend the drop for 2.5" and STRONGLY recommend it for the full 3".
If you shop around you can often find both Revtek and Cornfed kits used from folks who are "trading up". I sold my Revtek to a guy for $50 when I got tired of using the pucks as paperweights
Old Feb 6, 2003 | 03:09 PM
Dashunde's Avatar
I got to thinkin'
Does anyone have a used set of 1" or 1.5" Cornfed front spacers that would fit an '03 TRD Taco?
If so, I'd be interested in buying them.
Old Feb 6, 2003 | 03:17 PM
WATRD's Avatar
Re: I got to thinkin'
Contact Dread, I think he might have a set of 2" spacers for sale... or so I seem to recall hearing...
