lift question
Old Apr 19, 2003 | 09:52 AM
doink's Avatar
lift question
whats up guys
i have a 93 4runner with a 4 inch lift (well, until recently). within the past two weeks i have added a arb bumper with winch and a custom rear bumper. with all the added weight, it has brought my runner down. i was planning on getting the SAW torsion bars to help out with the load up front, and maybe crank them up a bit to regain some of the lost height. any suggestions for the rear?. could it be possible to put a spacer ontop of the coil spring to regain some lift?.
Old Apr 19, 2003 | 09:59 AM
Corey's Avatar
Co-Founder/Administrator
You could do what Luke did.
https://www.yotatech.com/forums/show...&threadid=3974
Go with the Downey 1.5" rear lift that is an add on to their 1.5" coils.
It includes a spacer puck and longer rear swaybar endlinks.
What coils do you have now?
Whatever you have back there, you will need the longer ss brakeline when you raise it higher.
Old Apr 19, 2003 | 10:01 AM
doink's Avatar
i have a 4inch lift from pro comp on there already, so, everything has been extended to compensate for the 4inches. the coils back there are the ones that came iwth the pro comp lift.
Old Apr 19, 2003 | 10:04 AM
Corey's Avatar
I'd look and see what size All Pro's spacers are too.
I am not sure if theirs is steel, or plastic.
It sounds like the coils you have now are similar to the Downey ones I run, and if you have the extended brake line already, perhaps the spacer will work from Downey.
Probably give Downey a call and see what they think also.
You might also need longer rear shocks unless you have them already.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
4Runnin2000
Jul 29, 2015 06:09 PM
coffey50
Jul 28, 2015 10:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
