Lift noise, Help!
Old Mar 29, 2007 | 01:45 PM
zberch's Avatar
Lift noise, Help!
So I installed my OME 3" coil lift from toytec. It has a small front spacer as well. I keeped the OEM front struts put Bilstein's in the back. It rides nice but there is a noise coming from the front (seems to driver side) sounds like two washers hitting together whenever i hit a bump. What could this be??
Thanks
Old Mar 29, 2007 | 01:53 PM
ROOFGOOF's Avatar
Check your sway bar and make sure the bolts are tight.
Were you certain that the coil spacer was seated correctly?
Get back undernieth it and look around at all of your connections to make sure nothing came loose. Your rig shouldnt be making those noises.
Throw some pics up too!
Old Mar 29, 2007 | 03:24 PM
Firefightertaco's Avatar
you probably didn't tighten the strut nut down far enough so were it would seat on the part of the strut where its flared out so that the washers and bushings between the top out plate, i did the same thing and its pissing me off, every time u hit a bump you hear that washer clanking around.
jashoeuh
Nov 18, 2024 08:08 AM
genuinegemini
Aug 3, 2015 04:56 PM
PlayAwhile
Jul 20, 2015 11:36 AM
razorman8669
Jul 12, 2015 12:13 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
