Lift kits
Old Sep 10, 2002 | 07:38 PM
seaskidoo's Avatar
Lift kits
I've been looking for a lift kit for my 99 4runner but I can't find anything that will lift it significantly. Has anyone found anything? I'm looking for about 5 or 6 inches total between body and suspension lift.
Old Sep 10, 2002 | 07:50 PM
Beowulf's Avatar
Welcome to the boards! If your 4Runner is 4x4 the max lift you can go without tearing up your CV's is 2.5"- 3". There are many options to go with for a 2.5" lift.
Old Sep 10, 2002 | 07:55 PM
seaskidoo's Avatar
Is there any type of body lift out there for a 99 4runner?
Old Sep 10, 2002 | 08:09 PM
jx94148's Avatar
Yes. Your best bet is to contact Roger Brown of 4Crawler Offroad. He can make a custom kit for you of better quality than any mass market kit with idiot-proof instructions. He'll reply to e-mails very quickly and thouroughly. His prices are less than most alternatives also. I had him make a custom 1.5 inch kit for me and it was very easy to install.
Here is Roger's bodylift info page.
Old Sep 10, 2002 | 08:54 PM
Beowulf's Avatar
You could do a combo body/suspension lift with pretty good results. Why do you want to go so high?
Old Sep 11, 2002 | 04:16 AM
seaskidoo's Avatar
I want to go so high becausse I want to be able to fit at least 33x12.5 under it.
Old Sep 11, 2002 | 09:36 AM
data's Avatar
Senior Member
To fit a 33x12.50x16 tire underneath your 99 you need a suspension lift and a 3" body lift. You will also need to do some fender trimming and seam pounding. I've been talking about this with "VaBeach99Jade" from the ODW forums. More info can be found on this thread.
http://www.outdoorwire.com/ubb/ultim...=012908#000000
and you can view pics of his setup...
http://community.webshots.com/user/luvsikpupp
If you are close enough to VA, you could take your ride to him for the 3" body lift. I'm over 1,000 miles away and still debating on whether the trek is worth it or not. I've never been to that part of the US before, so I might just take off work and drive!
Old Sep 11, 2002 | 11:43 AM
seaskidoo's Avatar
Really!? With 6 inches of lift I still need to cut and hammer stuff? I used to have a tacoma pick-up and fit 32x11.5" tires under it without doing anything.
Old Sep 11, 2002 | 11:47 AM
data's Avatar
Senior Member
yes i beleive so. i still rub on full turn with my 285/75/16's, but then again i haven't beaten the seam that much. i have done some massive amounts of trimming. as of right now i do still plan to drive up to VA to get the lift done, hell i need a vacation anyways
Old Sep 11, 2002 | 11:55 AM
seaskidoo's Avatar
I went to your website and looked at your suspension pictures. Is that a 3 inch suspension lift? If so did it actually raise it 3 inches? And how was it to put on?
Old Sep 11, 2002 | 12:37 PM
data's Avatar
Senior Member
Well the coilovers are set to 3", but with almost 200lbs of weight added to the front I don't see that much. The front shocks were not hard to install after a little instruction from the master mechanic
Sep 4, 2015 09:27 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
coffey50
Jul 28, 2015 10:55 AM
kirkrunner
Jul 27, 2015 07:59 PM
