Old Apr 20, 2016, 09:04 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Steering & Suspension Guides
Print Wikipost
Leaf springs sitting on exhaust...
Old Nov 20, 2006 | 03:44 PM
YotaBum's Avatar
Right now, sitting in the driveway, my rear passenger leaf spring is touching the the exhaust. I'm just now noticing this. Apparently when I get any downward wheel travel in that fender, the springs are hitting my pipes. In one of the pictures you can see that the rubber clip is broken from the spring pressing down on the pipe. I'm worried about this causing leaks or even worse, ripping out my muffler/exhaust. You guys with lifted Tacomas how did you fix this problem?? Can I run a straight pipe out the back from the muffler?? Is there enough room?? Where do your pipes exit?? Thanks guys....
Alex
Old Nov 20, 2006 | 03:49 PM
YotaBum's Avatar
GOT IT...
http://Name:  Leaf.jpg
File Type: jpg
File Type: jpg
Old Nov 20, 2006 | 05:06 PM
rcars4life's Avatar
photobucket.com
Old Nov 21, 2006 | 11:04 AM
BajaRunner's Avatar
Im guessing you did not move your exhaust after installing any suspension upgrades, right?
Check out TTORA.com... The Tacoma guys have to reroute their exhaust (just by putting a new hangar) after doing any sort of suspension changes in the back.
The other option is just to take a sawzall to it, like I did.
Old Nov 21, 2006 | 03:20 PM
JBSTRD's Avatar
Sawzall it under your truck or have an exhaust shop re-route it over your leaf springs. It is rubbing because you added shackles.
I prefer the sawzall method, that is what I did.
Old Nov 21, 2006 | 03:46 PM
Elton's Avatar
cut it of from the muffler and run a turn down
Old Nov 21, 2006 | 04:07 PM
GaTaco's Avatar
x2 for cutting it off. It could get hung up on something if you wheel hard. Here is how I cut mine:
88sasturbotoy
Jan 30, 2026 01:57 PM
nvdesertrunner
May 11, 2020 08:18 PM
4x4-runner
Apr 18, 2017 09:08 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
Greene916
Aug 10, 2015 01:45 PM
