Is this knock sensor bad? NEED ASAP!
Old Apr 21, 2008 | 09:46 AM
Bird333's Avatar
1998 4-cyl 4Runner
I did I continuity test on the knock sensor itself. It starts with 0 ohms and then rises to about 84 ohms. The manual says if there is continuity replace the sensor. I am not sure because it doesn't stay at 0 ohms. Before I order a new sensor, is it bad?
TIA!
On another note does anyone know how to remove the pin from the connector that goes to the knock sensor?
Old Apr 21, 2008 | 01:56 PM
Team420's Avatar
I have been trying to figure out this same thing for a week now, i dont know to test the knock sensor..although if there is not supposed to be continuity, that may answer my question. i would have thought there should be tho.
As far as removing the pin..you need a real small screwdriver like one used for eye glass repair, or jewelry repair.... inside the connector should be a small plastic piece that kinda locks the pin in there, if you are careful you can pry that out, then just pull the wire and pin out...at least thats how it worked for me...I should note that i have the 3VZE motor, not 22re
Old Apr 23, 2008 | 02:56 PM
Bird333's Avatar
Well apparently the sensor is bad because a brand new sensor has NO continuity at all. Just FYI.
nonstop
Jul 24, 2015 06:29 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
yourrealdad
Jul 21, 2015 11:13 AM
keithporter83
Jul 18, 2015 12:37 PM
smiley52
Jul 11, 2015 05:16 AM
