Knock sensor=bad
Old Apr 27, 2003 | 01:47 PM
Los Gatos?'s Avatar
Knock sensor=bad
How much does one of these puppies cost? can I get on from someplace other than the stealer? does bosch make an equivalent part? There aren't too many auto parts stores around here, just a foreign auto parts store (good stuff good prices) and some wall-mart type stuff. There is a stealer but I don't want to go there if I don't have to. I can't find a knock sensor online ANYWHERE. How much should it cost???
Old Apr 27, 2003 | 08:13 PM
byondevl's Avatar
http://www.california.com/~eagle/knock.html
instruction are for a gm, but you may be able to use them to build for toyota.
Old Apr 29, 2003 | 06:01 PM
Los Gatos?'s Avatar
Can I buy one somewhere instead?
Old Apr 29, 2003 | 07:07 PM
DH6twinotter's Avatar
Hey,
I found one at Pep Boys. I've looked at every other parts store too. I think I paid around $160 for it. However, check with your dealer. After I installed it, I found out that the dealership price was about the same (if I remember correctly). So, check with your dealer, then I guess check with Pep Boys. Maybe Pep Boys has a web site you could find it at? I dunno. Make sure you tell them you want the knock sensor. For some reason, people kept on thinking I wanted an O2 sensor.
You will also have to buy the intake manifold gaskets, plenum gasket, coolant bypass intake gasket (or whatever that's called), and a few copper O-rings for the fuel lines. I found the gaskets at either Auto Zone or Advanced (Can't remember which). They had a whole package that came with it all for around $90. Dealership wanted like another $80 or so. I would have gone with the dealership for the gaskets, but funds forced me to go the cheapest way. :cry: That also forced me to do it myself. Tell you what, I sure did learn a lot doing that repair.
Well, have fun.
DH6twinotter
Old Apr 29, 2003 | 07:27 PM
I found the part number for the one at Pep-Boys. It is S8646 made by Borg-Warner. Never heard of them. It was a special order and came out to $160.23 with tax.
Well, have fun.
DH6twinotter
Old Apr 29, 2003 | 07:59 PM
FattyCBR's Avatar
If you install it yourself make sure you follow the torque specs religiously, they are very sensitive to overtightening.
Old Jun 2, 2003 | 08:28 PM
jay-q's Avatar
at the risk of sounding ignorant...... how do you know when you have a bad knock sensor? *wondering*
Old Jun 3, 2003 | 06:12 AM
rimpainter.com's Avatar
You will have a severely retarded engine (no pun intended).
Old Jun 3, 2003 | 07:40 AM
95_4X4Runner's Avatar
From talking with Toyota mechanics, and experience with Supras, knock sensors don't go bad that often, (no moving parts), the wiring between the sensor and the ECU usually goes bad, most likely on the engine side, as it gets quite hot in the area. I think I'd verify the wiring is good before I bought a knock sensor....
The mechanic who installed my 3VZE recommended that I change a portion of the knock sensor harness that's attached between the heads, he's seen those go bad a lot, they get "crunchy" from the heat.
icentropy
Sep 16, 2020 02:47 PM
nonstop
Jul 24, 2015 06:29 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
keithporter83
Jul 18, 2015 12:37 PM
smiley52
Jul 11, 2015 05:16 AM
