Keys and remote stolen, what to do?
Old Jan 26, 2007 | 05:34 PM
Rivalred's Avatar
Originally Posted by SC4Runner
GODDAMNIT!!!
So, I looked on the manual how to disengage the brain unit. Basically erase it of any remotes. I can't do that because one I put the neg terminal on, it just beeps to ลลลล, even if I have the master key (that I found) in the ignition in the ON position.
So then I said, screw this, and unplugged all the connections in the front of the brain. Wont let me start the car!! WTF!?!
This is pissing me off . How do I disengage this thing when its in automatic alarm mode?
I would wait for Bob to post his information or if you can find the information online here. I thought you needed a scanner of some sort to reprogram it to certain settings especially now that it is locked down (dealer only now?).
Old Jan 26, 2007 | 06:54 PM
DrBeau's Avatar
I imagine Bob would rather tell him via PM. Alarm disarming techniques aren't something you generally like to publish in the public.
Old Jan 26, 2007 | 06:59 PM
User 051420's Avatar
FWIW, the alarm should turn off by itself after a few minutes...at least mine does. From there, reprogram it.
Old Jan 26, 2007 | 08:01 PM
Rivalred's Avatar
Yeah, didn't think about that... Good Point...
Old Jan 26, 2007 | 08:06 PM
  #25
Bob_98SR5's Avatar
SC,
check your PM.
bob
Old Jan 27, 2007 | 04:43 AM
  #26
neliconcept's Avatar
Can you change locks to the 4runner? possible?
gay festival? what were you doing there?
Old Jan 27, 2007 | 08:54 AM
  #27
BajaRunner's Avatar
Yeah, I donno if you can change the locks or not. I think Id like to. I am going to Toyota and see what they say, I guess.
So I just pulled the fuse that went to the horn, and went and held the button down. Took a little while, but, finally disengaged.
You can erase the memory of all remotes.
Gay festival, who mentioned any gay festival?
Old Jan 27, 2007 | 09:14 AM
  #28
itsmeagain5789's Avatar
my 95 has an on and off swich under the dash, unplug the battery and turn switch off. and ive beeen good like that.
Old Jan 27, 2007 | 10:01 AM
  #29
HuskyRunner's Avatar
If it's anything like a house lock, all they do is move the tumblers so that the old key won't work. For our house it was like $10 a lock.
Old Jan 27, 2007 | 09:40 PM
  #30
CTRJ's Avatar
I work at a Lexus dealership, so I am not 100% this will transfer but for what it's worth...
We can replace all the lock cylinders for our cars. They come with new keys and the locks can be coded so you only need the one key for all of them. It's an expensive route. My 4Runner actually has different door lock keys than what fits the ignition. I carry two keys instead of one, not that big a deal.
I would take the truck into Toyota, let them deal with it. It's expensive, but having the piece of mind knowing that your truck is safe should be worth it.
Old Jan 27, 2007 | 10:10 PM
  #31
CJM's Avatar
CJM
Turning the key 3x doesnt work to disarm anymore?
Old Jan 27, 2007 | 10:19 PM
  #32
One_96TR4's Avatar
[QUOTE=CTRJ;50410182] I carry two keys instead of one, not that big a deal.[QUOTE]
Sounds like someone replaced your ignition switch before. Should have originally come with one key for the doors and ignition.
Anyhow You don't necessarily have to take it to a stealership. If you have a mechanic that does your work they can easily order the new lock cylinders and change all the door locks and ignition or they can just change the ignition. Wouldn't hurt to price it at a stealership though.
zytra
Jan 24, 2019 03:16 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
PNW94Runner
Sep 29, 2015 02:55 PM
JamesDINAN
Sep 22, 2015 05:37 AM
