keyless entry questions
Old Apr 19, 2008 | 10:59 PM
kernel's Avatar
Does anyone know where the factory keyless entry module is for a 99 4unner (not an alarm)? Also, is it possible to change from the the drivers door unlocking first to having all doors unlock at the same time?
Old Apr 20, 2008 | 01:33 PM
kernel's Avatar
Anyone know?
Old Apr 20, 2008 | 08:10 PM
Kerby J's Avatar
hey man i found that in my '01 the module for mine was in the rear hatch go figure i know but the only way that i know of changing it from jus unlocking the drivers door first then the others is to put in an aftermarket alarm or keyless entry and i would still do an aftermarket alarm because it is worth it
Old Apr 20, 2008 | 08:44 PM
element's Avatar
***Edit - I can't read! Thought you were looking for a remote
Kerby is correct. It is in the rear hatch.
I don't know if you can change the system to unlock all doors with the first button press. It might be a setting in the body control module that could be set with a scan tool, but I'm not sure.
Maybe someone else can shed light on this.
Last edited by element; Apr 20, 2008 at 08:48 PM. Reason: fighting illiteracy one post at a time
jeffold13
Sep 29, 2015 10:31 PM
jmyer72
Aug 20, 2015 07:55 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
