Key
Old Mar 12, 2007 | 05:46 PM
RETRO's Avatar
Key
I went to Home Depot to get a key made the salesman said he could not make on cause my key has the chip in it..I know my wifes cars ( Corolla ) has the chip but did not think a 04 Tacoma does..
Old Mar 12, 2007 | 06:30 PM
profuse007's Avatar
my info says no chipped key.
if you got metal-headed key, then its definitely not.
Old Mar 12, 2007 | 06:36 PM
wjwerdna's Avatar
i get told that too, just because its a big plastic end... then I point out that it is all ready a cheap copy, and just make me a darn key... (on a '99)
you may, I don't know, but if still doubtful, just have them make one anyway, and if it doesn't start the truck, you have a chip if they complain, just say its for the doors only, or for the hitch, or you want a separate one for the glove box so you don't have to take keys outta the ignition, or dealer maybe for verification.. plus they can make pretty much guaranteed not crappy keys from your VIN
Old Mar 12, 2007 | 06:41 PM
RETRO's Avatar
it's the same key that came with my 95 T-100 has the black rubber on the top of the key..My wifes key is the same key 35 but the rubber part is thicker and taller that has a chip in it...Thought i knew what iwas talking about come to find out i did..Thanks guys..as always a big help
Old Mar 12, 2007 | 06:53 PM
BajaRunner's Avatar
I was unaware that they had chips, but, the only way to know is by calling the dealer.
Old Mar 13, 2007 | 04:57 PM
pmbazus's Avatar
Key
I have a 2004 4WD reg cab Tacoma. I have had a key made and it works just fine. It is a regular key with no rubber on it.
Old Mar 13, 2007 | 05:02 PM
HUTCHSTACO's Avatar
it should not have a chip
Old Mar 14, 2007 | 04:44 AM
RETRO's Avatar
Update
Went to Home Depot and had a key made it would unlock the door but not turn the ignition..Went back had them tell me they can't cut a key for truck cause it had a chip in it..I told her no it does not..I told it unlocks the door and that's it she said that becaue it needs to chip to start the motor..tried to tell her it was cut wrong..She did not want to here that..Left went to Lowes got a key cut that works...
Old Mar 14, 2007 | 05:09 AM
Fo-runna's Avatar
Ha, go back and tell her the one you got at Lowes seems to start the truck just fine!
Old Mar 14, 2007 | 08:09 AM
RETRO's Avatar
ah i did that did not go over to well with Home Depot
83yotastockR
11
Nov 10, 2015 06:54 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
PNW94Runner
Sep 29, 2015 02:55 PM
JamesDINAN
Sep 22, 2015 05:37 AM
JHalcyonM
Sep 14, 2015 01:10 AM
