Just joined the 150,000
Old May 19, 2008 | 10:01 AM
jimig's Avatar
Talking Just joined the 150,000
miles club. Just wanted to share the joy. 2002 Tacoma 2.7 original clutch insert bigpatontheback.jpg
Old May 19, 2008 | 10:13 AM
mkgarrison5's Avatar
congrats. that much closer to buying a new truck huh? LOL.... 150k on an 02? drive much? i thought i drive a lot
Old May 19, 2008 | 10:18 AM
Kiroshu's Avatar
Dang. My 95 Yota runner has that. 151,000 Miles. Its good Your getting use out of your yota truck. Keep on truckin in a Toyota man. Its the only way to go.
_________________________________________
95 Toyota 4runner SR5 V6 3.0 Automatic 4x4 151,000 Miles
Old May 19, 2008 | 10:23 AM
jimig's Avatar
Yea, Driving to different projects can add up miles in 6 years. I just broke it in though.
Old May 20, 2008 | 08:19 AM
Quattro15's Avatar
I'm at about 160k with my '99 taco. Can't tell unless you check the mileage though!!!
Old May 20, 2008 | 09:55 AM
gpcollen1's Avatar
My 99 4runner just flipped 150k on saturday. Still running like she was at 50k.
Old May 26, 2008 | 02:50 PM
4runnagurl's Avatar
I am at 144 and Im starting to get nervous. It takes like a second longer to start now.
I love my runner but the owner before me (who had it for 6 years) did not take good care of it so I am afraid it won't last me :[
Old May 26, 2008 | 06:38 PM
icerunner's Avatar
Just a quick $0.02,
you've made it to 144K so far and thats pretty good. I'm at 153K now on my 99SR5 and I'm still going strong. Alot of the engine failures you hear about are at heavy acceleration at 4000 to 5000 + RPM's (near or over redline)...If you let your rig warm up properly (by light driving right away..not ideling) and don't "get on it" too bad I think you'll be ok... I sure hope so.
Old May 26, 2008 | 07:40 PM
4runnagurl's Avatar
thanks. that makes me feel better. people were starting to tell me it wasn't ganna make it.
i take care of my car. i try not to "get on it" too much. haha but ill admit i kinda drive like a guy in a fast car, but i've been cutting that out. i think i will be good.
Old May 26, 2008 | 08:32 PM
ozziesironmanoffroad's Avatar
you got a long way to go, ma'am. im currently resting comfortably around 270,000 miles.
Old May 26, 2008 | 08:36 PM
904_runner's Avatar
Haha, my 3.0 just flipped 248,000 miles the other day.
My moms 3.4 has 158,xxx i think!
Originally Posted by icerunner
..If you let your rig warm up properly and don't "get on it" too bad I think you'll be ok... I sure hope so.
Exactly. I almost always let mine warm up to operating temperature before driving it. I sure your's will be fine 4runnagurl
Old May 27, 2008 | 04:09 AM
icerunner's Avatar
things to think about
You know at 144K miles is great for any vehicle, and its not unusuall that some thing may start to go... the battery if its original, starter, possibly the alternator, our water pumps have been known to leak a few drips...
Is your starter is starting to work slowly? If so, the contacts may be wearing out. Another point is that the spark plugs which are 30K to 45K (max) mile plugs may be due for a change...that is, if you have not done so allready. Also, if your vehicle was abused, why not switch to a slightly thicker, High miliage formula oil like Mobil 1 10W30. It will cost more, yet it may help clear out some sludge caused by P.O abuse. You can be perfectly fine with changeing it every 5K 6K Miles....? Castrol GTX (for sludge deposits) and Mobil clean 5000/7500 are pretty good too... just a thought.
later
Old May 27, 2008 | 04:27 AM
Belize Off Road Team's Avatar
I'm only at 113,000miles in a 1991. So you must have seen alot of country!
Old May 27, 2008 | 05:05 AM
1stgen4gunner's Avatar
205,000 miles and runs better en the day I bought it.
Old May 27, 2008 | 05:28 AM
X-AWDriver's Avatar
I'm now 11,700 away so I should hit that in the 14 months.
Original clutch? I'm impressed.
Old May 27, 2008 | 07:56 AM
cackalak han's Avatar
I'm at 109500. Not even close to the half way point.
He said, NOT idling. You should drive right after you start the truck and take it EASY until it warms up. Idling is not necessary, is not good for the environment, you take a hit at the gas pump, and it doesn't allow your drivetrain to warm up properly. When you start driving after start up, it allows your engine to warm up ALONG WITH your diff's, x-fer case, transmission, etc.
Old May 27, 2008 | 08:02 AM
881stGenRunner's Avatar
awesome man, good to hear. I just turned over 226,100
Old May 28, 2008 | 02:15 PM
4runnagurl's Avatar
yeh i don't it just sit after i start it. i usually dont have time. hah but i will just slowly cruise around the block until it warms up to the right temp.
Old May 28, 2008 | 03:58 PM
904_runner's Avatar
Just hear me out, i usually run out in the morning, start up my truck run inside and brush my teeth, then run back out, and its usually warm. Thats maybe 3-4minutes tops.
I then take it easy, i still don't drive it like a maniac, but take it easy.
What i was getting at, was to just let it warm up and continue to take it kind of easy.
I always see people start it up and drive like a bat out of hell right away, and i try to avoid that.
Old May 30, 2008 | 05:59 PM
4runnagurl's Avatar
yeh, sometimes i am running late and then i hop in.. and i hate that.
im feelin better with my runner lasting. its gana make it. i can tell. im going to take care of it.
im about to go through it and check everything to see if anything could be replaced with a new one.
