itty bitty lift
Old Sep 1, 2010 | 10:34 AM
bak3rme's Avatar
itty bitty lift
i have a 99 sr5. running 265/70/16's
looking for a small lift maybe 1 inch...1.5 max
i can get a set of used 265/75/16's for pretty cheap. however would it be noticable? would i notice an increase in height switching from /65's to /75's?
i've tried searching for pics of it compared to stock, but no luck
any pics?
Edit* im running bald tires right now but my front tires show 30"inches. my back tires show 29.5ish inches. back tires are 265/70/16 and 10% tread left. the front shows 30 because its 270/70/16. but those are bald as well.
Old Sep 1, 2010 | 11:30 AM
Guyechka's Avatar
I was looking for a small lift on Toytechlifts.com, which is pretty complete, but the smallest they had was 2" for a suspension lift. Plus, it's more expensive than what you'd save on the tires. You can do a 1" body lift for less.
Old Sep 1, 2010 | 11:54 AM
bak3rme's Avatar
hwo much would a 1'' body lift be do you think? because the /75 size tires I can get used for very cheap i know a guy that has one of those used tire shops
Old Sep 1, 2010 | 01:33 PM
Guyechka's Avatar
$120 for the 1" lift kit. Go check it out at toytechlifts.com.
Old Sep 1, 2010 | 01:37 PM
brian2sun's Avatar
You don't need any lift to fit 265/75/16s on a '99 4x4 (not sure if you were aware). I ran that size for years at stock height on my '97 and never rubbed off road.
Body lifts are ~$100-125. You can go up to 1.5" without having to buy anything else like the radiator drop, steering extension (altough my '97 needed this), tranny/t-case linkage, etc... BLs over 1.5 require these additional parts. You'll probably want to lift your front bumper up so you don't have a gap so check out 4crawler.com, he's got all that stuff. Should be ~$125 for the lift + bumper lift brakets.
Old Sep 1, 2010 | 01:38 PM
dropzone's Avatar
Fossilized
you know a lot of the answers you are looking for $$$ wise of lifts could be answered by doing a little research on your part.
Old Sep 1, 2010 | 03:14 PM
JWaldz's Avatar
since you have a '99 I dunno if you already have them, but if you don't you can achieve a small amount of lift using the '99 TALL COILS. Most the Limiteds in '99 had them. Like said before me as well as time & time again, search cus this information is out there.
Old Sep 1, 2010 | 03:22 PM
poweraid's Avatar
What about a leveling kit?
Old Sep 1, 2010 | 04:34 PM
bak3rme's Avatar
hows that work out?
Old Sep 1, 2010 | 06:56 PM
JWaldz's Avatar
daystar leveling kit.. THIS should get you started
Old Sep 2, 2010 | 09:10 AM
rob17san's Avatar
Body lift is probably best for you since you stated you only want 1 to 1.5"
Old Sep 3, 2010 | 07:23 PM
Nevin's Avatar
If everyone did that there would be no need for YotaTech.
Old Sep 3, 2010 | 07:25 PM
xxxtreme22r's Avatar
most of their answers when searching through google are on Yotatech.
Old Sep 3, 2010 | 07:28 PM
Nevin's Avatar
yotatech
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
