Iridium or Bosch 4 spark plugs?
Old May 12, 2005 | 03:14 PM
kyle_22r's Avatar
save the bosch plugs for volkswagens. i had then in my old 2wd toy and they'd make the engine miss at mid-high RPM(3000+)
Old May 13, 2005 | 07:12 AM
Andrey's Avatar
One more vote for Denso Iridiums. They're expensive, but very much worth it! I run mine with S/C and 7th injector kit and couldn't be happier.
-- Andrey
Old May 13, 2005 | 09:14 AM
2001Millrunner's Avatar
ngk seems to work the best for me
Old Jul 3, 2005 | 09:25 AM
bob200587's Avatar
sitting here with my NKG iridiums, i just gapped them and im gonna install when the truck cools off, i have just plain bosch platinums in there now, im hoping to see a big difference. i have bosch wires too any suggestions on other brands? Accel? MSD? anything else i should consider. its not quite time, but i might go up to 8mm if i feel like it.
Old Jul 3, 2005 | 06:24 PM
  #25
Adam F's Avatar
Stay away from Bosch. I've had 2 Honda's that came to me with a misfire, and I pulled out Bosch plugs out of both and put in NGK's. One Bosch actually had a broken electrode.
Denso for Toyotas, NGK for Hondas.
Old Jul 3, 2005 | 07:13 PM
  #26
Yamaha+Toyota=Fun's Avatar
I run normal old NGK V-powers. Cheap and they work.
Old Jul 3, 2005 | 09:16 PM
  #27
94-RUNNER's Avatar
Thumbs up denso Iridiums
I have always been a factory spec kinda person , BUT , I put DENSO IRIDIUMS in my Runner and have never been happier ! They now have been in there untouched for over 45,000 miles and perform flawlessly. At 181,000 plus miles I still very loaded get betwwen 20-21 miles to the gallon on the highway and 17-18 mile to the gallon in town . I have a 5-speed with 32-11.50/15 Bfg AT-KO and have a very heavy foot. Granted I give my RUNNER ever service that it is due and probably more than it needs but I am a firm believer that there is no way that you will ever over service your vehicle. You take care of your truck and it will take care of you . Give it nothing but the best money can buy and it will return the same: PERFORMANCE AND RELIABILITY ! ! ! ! I do run a K&N filter, synthetic oils in everything, new fuel filter every 10,000 miles and a can of SEAFOAM in every third tank of fuel. When I bought this Runner of of E-BAy 2 years ago I was getting at the best unloaded 13-15 on the highway. Now with a few minor changes look what I have achieved ! The other big thing that I did was to get those terrible automatic hubs off there and put a set of factory AISIN hubs of a 1986 4-Runner on and that really help a lot not to mention saveing my drivline a lot of wear & tear !
WANT TO BUY ENEXPENSIVE DENSO IRIDIUMS CHECK OUT
CLUBPLUG.NET THE BEST PRICES THAT I COULD FIND AND VERY GOOD CUSTOMER SERVICE !
Old Jul 4, 2005 | 06:41 AM
  #28
Captain_Toyota's Avatar
Denso Iridiums all the way! They will outlast any other spark plug on the market. A lot of the new Toyotas come with them right from the factory and Toyota has now extende the spark plug change interval to 120,000 miles (up from 100,000). That should tell you something about the durability these plugs have.
I ran them in my snowmobile the past 2 winters and had absolutely no problems with them. I usually replace the plugs after 1000 miles but when I took them out they looked like brand new so I ran them another 1500 miles untill I sold that sled.
Cap'n
Old Jul 4, 2005 | 08:32 AM
  #29
kyle_22r's Avatar
i'm now running a hot ignition(.050 plug gap anyone?) and i've found that it beats the crap out of the NGK plugs. i'm now running autolites and it seems to be playing nicer. no difference from NGK in driveability or performance, but they just seem to hold up better.
remember, my ignition isn't stock though...
Old Jul 4, 2005 | 08:54 AM
  #30
88yotaboy's Avatar
Originally Posted by shiftless89
I was given a set of bosch +4's for my wifes suburban from the rep. Let me tell you that from research I've done and personal experience bosch plugs are KRAP, worse fuel MPG, eratic idle, misfires, pinging ect! I left them in for 1000k miles just to do it, they got progressively worse! Unless you are needing a colder or hotter range plug (superchargers, turbos ect), stick with what it came with. OE plugs are inexpensive and just work like they are supposed to!
sorry to hijack.... but the 4runner im getting has a factory turbo.... so does that change what plugs i should put in it?... the guy im buying it from says he loves the bosch p +4s he has in his taco.... now im all confused
Old Jul 4, 2005 | 01:14 PM
  #31
kyle_22r's Avatar
with a turbo, you may want to use a colder plug. stick with NGK or denso, just ask for a plug with a cooler heat range.
Old Jul 4, 2005 | 02:28 PM
  #32
DavidA's Avatar
How about I ordered 6 new NGK platinums from URD and they called me the other day and said they shipped me Iridiums instead by accident and hope that I enjoy them.
I love URD for being so gracious...can't wait to try them out. Thanks URD...you are an upstanding company. You have a steady customer now from me.
Old Oct 17, 2005 | 10:11 AM
  #33
surf4runner's Avatar
bump
i've been running bosch Pt+2 in my 22re for over 120k (2nd set) and have not had a single issue with misssing or anything else. i put them in my 02 runr and have not exp'd any issues either(~10k). they definely work better w/ FI as they didn't seem to perform as well in my NA 510, it likes NGK. my 0.02 fwiw
Old Oct 17, 2005 | 12:01 PM
  #34
sandcrawler's Avatar
i have the same rig, junbug. and i use NGK or denso regular OEM plugs with NGK (blue) wires.
they're like $1.70/plug and the rig runs great.
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
accuracy
Aug 4, 2015 08:05 PM
defrag4
Jul 31, 2015 10:50 AM
