Installing ARB locker on a 3rd Gen 4Runner
Old Aug 26, 2004 | 08:09 PM
ranma21's Avatar
Hi all, I am trying to put locker to my 96Runner. Initially, I was trying to find a used Toyota e-locker with the axle assembly and front matching gear diffrential to do a direct swap without messing with the gear and stuff. But the cheapest I can find for the set-up cost about $1000. I am thinking to just go ahead and buy the ARB and do the installation myself. Is the installation pretty complicated or it can be done if I have time and that is not my primary vehicle? Part of the reason I wanna do it myself so that I can learn more stuff and know how it works. Thanks for any input and help
Old Aug 27, 2004 | 03:21 AM
george16's Avatar
It's pretty much straightforward. The ARB instructions are clear and easy to follow. If you're going to regear, then have somebody with you who knows how to do the gears especially in setting the correct backlash. Be careful on the o-rings for the locker. Majority of leaks and problems comes from improper installation of the o-ring. Here are some sites to get some info.
Locker install
Lars site
Hope this helps.
George
Old Aug 27, 2004 | 09:30 AM
ranma21's Avatar
Thanks George!! It looks like a pretty fun project!!! I might ask you some more question before I install mine if that is ok with you. Thanks again!!
Old Aug 27, 2004 | 10:39 AM
george16's Avatar
Not a problem . Glad I could help.
George
Old Aug 27, 2004 | 11:33 AM
Flygtenstein's Avatar
If you need to ask about installing an ARB, but probably should not undertake the operation yourself.
Installing one requires resetting the gears which takes tools, experience and time that most novices do not have.
Jun 1, 2021 01:51 PM
Jdgarrison
Oct 1, 2015 05:22 PM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
