Installing aftermarket stereo unit
Old Apr 5, 2006 | 11:30 AM
w99t4rweos's Avatar
i have a 6 speaker factory single cd player w/ am fm radio w/ power antenna. does anyone know , when installing a aftermaket h/u ,do you remove the factory amp sitting behind the head unit?
And what is the second smaller coxial looking plug in the back for ? I heard it might be for the power antenna, if so, how is it hook up to a aftermarket unit? I'm going to be using a slightly older pioneer cd player .
Thank you
Old Apr 5, 2006 | 11:47 AM
Bob_98SR5's Avatar
look in the tech section's electrical forum and look for 3rd gen stereo writeups
Old Apr 5, 2006 | 12:09 PM
TX2RUNNER1997's Avatar
if you aftermarket HU has an internal amp, then you need to take out the factory amp, and dont worry about the second connector
Old Apr 6, 2006 | 07:24 AM
gpcollen1's Avatar
Remove the Amp - You will need either a Harness adapter to attach to what exits the existing Amp (available multiple places like Cutchfield) to your new stereo or to cut that connector off and wire to that. I installed new speakers and tweeters in the front and it does sound better than it did with the stock speaker after the HU install. I did not install an Amp a new Amp - I like my hearing.
That second wire is an additional antennae wire - ignore it.
Old Apr 6, 2006 | 09:44 AM
w99t4rweos's Avatar
Hey Thanks for clearing the mud on this issue.
BTW, gpcollen1, what brand , model speakers and tweets did you use?
Thanks
Old Apr 6, 2006 | 10:07 AM
gpcollen1's Avatar
Oh Boy - They are Alpine (model #?????) - I bought them a few years ago (expensive at that time) and never installed in my van. They sort-of fit in my 4R - with a little modifcation they are just GREAT. I am never afraid to make a few nips and tucks.
There are many posts on HUs and speakers in these forums. I see that most people add Amps and Subs. My one recommendation if you replace the speakers and tweeters - - - Replace the Cross-over and run new wires into the door. i did not initially and ended up doing it later due to issues with the wires.
Old Apr 6, 2006 | 01:08 PM
w99t4rweos's Avatar
Thanks for the info!
theking11863
Mar 19, 2016 09:36 PM
gary4runner
Sep 24, 2015 12:53 AM
Sep 4, 2015 09:27 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
bryan34w
Jul 6, 2015 05:53 PM
